rtems_binary_semaphore_post from IRQ handler
Sun May 5 22:19:34 UTC 2019
On 6/5/19 1:55 am, Ярослав Лещинский wrote:
> Hello again,
> still have some troubles with post/wait binary semaphore sequence. Could someone
> suggest what is a right way when you're working with semaphore inside interrupts.
> I have sys call via spidev which is waiting for the binary semaphore. Semaphore
> released inside the interrupt. In some cases after several transmission I'm
> getting fatal: RTEMS_FATAL_SOURCE_EXCEPTION.
What type of fatal error are you seeing?
> I'll be really appreciate for any suggestions.
> BRs, Yaroslav.
> On Wed, 17 Apr 2019 at 16:25, Ярослав Лещинский <midniwalker at gmail.com
> <mailto:midniwalker at gmail.com>> wrote:
>     Hello,
>     I wrote spidev driver for stm32l4 mcu.
>     spi_trasfer function looks like:
>     static int spi_transfer(
>         spi_bus *base,
>         const spi_ioc_transfer *msgs,
>         uint32_t msg_count)
>         struct stm32l4_spi_bus *bus = (struct stm32l4_spi_bus *)base;
>         SPI_TypeDef *spix = (SPI_TypeDef *)bus->driver.spix;
>         enum spi_major_num num = get_spi_major_number(spix);
>         bus->msg = &msgs[0];
>         spi_bus_table[num] = bus;
>         spi_bus_table[num]->msg_count = msg_count;
>         spi_bus_table[num]->messages_left = msg_count;
>         int msg_error = spi_setup_trasfer(
>                 spi_bus_table[num],
>                 spi_bus_table[num]->msg,
>                 spi_bus_table[num]->messages_left);
>         rtems_binary_semaphore_wait(&bus->sem);
>         return (msg_error == 0)? 0 : -EINVAL;
>     Transmission proceeded via SPI IRQ + DMA IRQ. In DMA IRQ handler after dma
>     successfully transmitted all data I'm using rtems_binary_semaphore_post for
>     corresponding semaphore.
>         bool bus_is_broken = (bus == NULL) ||
>                              (msg_count < bus->messages_left) ||
>                              (msg_count == 0);
>         int ret = 0;
>         if(bus_is_broken == true)
>             return -EINVAL;
>         if(msgs->cs_change == true)
>             spi_css_deselect(&bus->driver);
>         if(bus->messages_left > 0)
>             const size_t msg_idx = msg_count - bus->messages_left;
>             ret = spi_do_transfer(bus, msgs, msg_idx);
>             bus->messages_left--;
>             if(ret != 0)
>                 rtems_binary_semaphore_post(&bus->sem);
>                 return ret;
>         else
>         return ret;
>     Currently I see that semaphore was successfully posted but control was not
>     returned to spi_transfer.
>     As I know there are can be some issues with a context switching.
>     Does rtems_binary_semaphore_post know about where control should be returned?
>     Thanks.
>     Kind regards,
>     *Yaroslav Leshchinsky*
> Kind regards,
> users mailing list
> users at rtems.org
