SMP working?
Mon May 6 06:01:14 UTC 2019
On 05/05/2019 21:37, Joel Sherrill wrote:
> The erc32 is a single core processor and smo is not going to work at
> all. You need to be using the Leon3 in the sparc family.
I use the erc32 GDB simulator quite often to run the tests with SMP
enabled. If you don't see any output, then something is not set up
correctly.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
