rtems_binary_semaphore_post from IRQ handler
Joel Sherrill
joel at rtems.org
Tue May 7 16:22:23 UTC 2019
On Tue, May 7, 2019, 11:11 AM Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> problem solved: that was silly mistake related to the task min size.
Stack minimum?
> Thanks for your support, guys.
> On Mon, 6 May 2019 at 17:16, Ярослав Лещинский <midniwalker at gmail.com>
> wrote:
>> Hello again,
>> >>Maybe
>> >>this is related to an interrupt with a too high priority, see also:
>> >>https://lists.rtems.org/pipermail/users/2019-April/033102.html
>> I have played around with priorities but no luck.
>> >>What type of fatal error are you seeing?
>> *** FATAL ***
>> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
>> R0 = 0x20009040 R8 = 0x00000001
>> R1 = 0x2000374c R9 = 0x00000005
>> R2 = 0x20009040 R10 = 0x2000f0d8
>> R3 = 0x00000000 R11 = 0x00000005
>> R4 = 0x20009040 R12 = 0x00000000
>> R5 = 0x00004000 SP = 0x2000a1b8
>> R6 = 0x2000ecf8 LR = 0x0000980b
>> R7 = 0x00000002 PC = 0x20003c80
>> XPSR = 0x60000000 VEC = 0x00000003
>> RTEMS version: 5.0.0.46b8638288a51cc175067be12a20301b3fb83ec7-modified
>> RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
>> f07d2b6e9ad70d62eb617a9f5515c5045ee0c119, Newlib
>> 08eab6396f678cf5e5968acaed0bae9fd129983b)
>> executing thread ID: 0x08b010002
>> executing thread name:
>> My application is a wlan ap initialization using TI sdk for cc3100. Using
>> this sdk, I'm creating separate tasks. Actually sequence of my actions are:
>> 1. pthread_create(&wlan_ap_thread_id, NULL, run_wlan_ap, NULL);
>> 2. Wait interrupt signal from chip
>> 3. Spawn a new thread using message queue.
>> 4. Start some kind of SDK magic: transmission via SPI. As I can see from
>> output before fatal there are over 8 successful transmission, the last what
>> I see it's a starting reading 8 bytes from device after that fatal occured.
>> >>I think you can trace the PC pointer to see what makes the FATAL.
>> using gdb: info symbol 0x20003c80 I'm getting
>> _POSIX_Threads_Objects + 2512 in section .bss
>> What am I missing?
>> Please suggest.
>> BRs, Yaroslav.
>> On Mon, 6 May 2019 at 08:06, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello,
>>> using rtems_binary_semaphore_post() in interrupt context is fine. Maybe
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> Kind regards,
>> *Yaroslav Leshchinsky*
> Kind regards,
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190507/8c7bb646/attachment.html>
