SMP working?
Eghonghon Eigbe eghonghoneigbe at gmail.com
Wed May 8 08:49:19 UTC 2019
Unfortunately the erc32 does not work for me. I have now tried to set up
the leon3 (similar to the erc32 in the quick start guide) however now I do
not even see an output for the normal hello.c example. I am assuming that
leon3 has to be set up differently but I could not find information on
that. I am basically looking for a board support package that supports
multiprocessing and for which I will be able to see the outpit. Would it be
possible to guide in this matter.
Regards
Suhail
On Mon, 6 May 2019, 8:01 am Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> On 05/05/2019 21:37, Joel Sherrill wrote:
> > The erc32 is a single core processor and smo is not going to work at
> > all. You need to be using the Leon3 in the sparc family.
> I use the erc32 GDB simulator quite often to run the tests with SMP
> enabled. If you don't see any output, then something is not set up
> correctly.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190508/8224edb8/attachment.html>
