GSoC 2019 Project Description
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Fri May 10 14:21:46 UTC 2019
What I think Mr. Huber was recommending was a benchmark program in C
submitted to rtems-libbsd/testsuite.  Then you can use your tracing
infrastructure to create the trace from the benchmark.
The RTEMS side of the test case is fairly straightforward.  I'll need
to learn how to run a task from the host running the test in parallel
to get it meaningfully automated, though.
On Fri, May 10, 2019 at 3:17 AM Ravindra Kumar Meena
<rmeena840 at gmail.com> wrote:
> Hi Sebastian, Jonathan
> That would be great if Jonathan could help us with a use case for tracing. But we would require trace data in Common Trace Format(CTF).
> Thanks
> On Thu, May 9, 2019 at 3:29 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Hello Ravindra,
>> welcome on board.
>> Jonathan Brandmeyer reported a libbsd performance issue some days ago:
>> https://lists.rtems.org/pipermail/users/2019-April/033185.html
>> Maybe he is interested to help us in this GSoC project with a use case
>> for tracing. For example, he could run its application with the tracing
>> enabled and some instrumentation. Afterwards, he could send us an
>> example set with recorded trace raw data.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Ravindra Kumar Meena,
> B. Tech. Computer Science and Engineering,
> Indian Institute of Technology (Indian School of Mines), Dhanbad
Jonathan Brandmeyer
Vice President of Software Engineering
PlanetiQ
