rtems_binary_semaphore_post from IRQ handler
    Ярослав Лещинский
    midniwalker at gmail.com
    Tue May  7 16:11:13 UTC 2019
problem solved: that was silly mistake related to the task min size.
Thanks for your support, guys.
On Mon, 6 May 2019 at 17:16, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> Hello again,
> >>Maybe
> >>this is related to an interrupt with a too high priority, see also:
> >>https://lists.rtems.org/pipermail/users/2019-April/033102.html
> I have played around with priorities but no luck.
> >>What type of fatal error are you seeing?
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> R0   = 0x20009040 R8  = 0x00000001
> R1   = 0x2000374c R9  = 0x00000005
> R2   = 0x20009040 R10 = 0x2000f0d8
> R3   = 0x00000000 R11 = 0x00000005
> R4   = 0x20009040 R12 = 0x00000000
> R5   = 0x00004000 SP  = 0x2000a1b8
> R6   = 0x2000ecf8 LR  = 0x0000980b
> R7   = 0x00000002 PC  = 0x20003c80
> XPSR = 0x60000000 VEC = 0x00000003
> RTEMS version: 5.0.0.46b8638288a51cc175067be12a20301b3fb83ec7-modified
> RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
> f07d2b6e9ad70d62eb617a9f5515c5045ee0c119, Newlib
> 08eab6396f678cf5e5968acaed0bae9fd129983b)
> executing thread ID: 0x08b010002
> executing thread name:
> My application is a wlan ap initialization using TI sdk for cc3100. Using
> this sdk, I'm creating separate tasks. Actually sequence of my actions are:
> 1.  pthread_create(&wlan_ap_thread_id, NULL, run_wlan_ap, NULL);
> 2. Wait interrupt signal from chip
> 3. Spawn a new thread using message queue.
> 4. Start some kind of SDK magic: transmission via SPI. As I can see from
> output before fatal there are over 8 successful transmission, the last what
> I see it's a starting reading 8 bytes from device after that fatal occured.
> >>I think you can trace the PC pointer to see what makes the FATAL.
> using gdb: info symbol 0x20003c80 I'm getting
> _POSIX_Threads_Objects + 2512 in section .bss
> What am I missing?
> Please suggest.
> BRs, Yaroslav.
> On Mon, 6 May 2019 at 08:06, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> using rtems_binary_semaphore_post() in interrupt context is fine. Maybe
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Kind regards,
> *Yaroslav Leshchinsky*
Kind regards,
URL: <http://lists.rtems.org/pipermail/users/attachments/20190507/9bc040aa/attachment-0002.html>
