assertion "first != _Chain_Tail( &ready_queues[ index ] )"
Jython googcheng at gmail.com
Wed May 22 02:34:54 UTC 2019
finally i find it's usleep call causes that
while(retry && ((RCC_BDCR & 0x02) == 0))  // External low-speed oscillator
> ready
> retry--;
>             usleep(5000);
>             #if 0
>             volatile int k = 0;
>             (void)k;
>             int j;
>             for(j = 0; j < 1000; j++)
>                 k = k + 1;
>             #endif
On Wed, May 22, 2019 at 2:54 AM Gedare Bloom <gedare at rtems.org> wrote:
> This just covers up some bug. When the system overhead increased to check
> the stack contents, it might modify the timing enough to obscure a race
> condition. Since the stack checker didn't report anything, you probably
> don't have a blown task stack. (But you could still have a function stack
> overflow.)
> On Fri, May 17, 2019, 4:21 AM Jython <googcheng at gmail.com> wrote:
>> thanks a lot!
>> when i add #define CONFIGURE_STACK_CHECKER_ENABLED
>> problem disappeared, but i still dont understand how it happend
>> On Fri, May 17, 2019 at 6:00 PM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 17/05/2019 11:58, Jython wrote:
>>> > hi, Huber!  how to debug general stack corruption?
>>> The first thing is to turn on the stack checker.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190522/96c90037/attachment-0002.html>
