Shell bug(?)
Mathew Benson
mbenson at windhoverlabs.com
Fri Nov 1 21:51:47 UTC 2019
So no matter what priority the shell task is initialized as, it preempts
all other tasks?
On Fri, Nov 1, 2019 at 11:36 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Nov 1, 2019, 11:24 AM Mathew Benson <mbenson at windhoverlabs.com>
> wrote:
>> My shell task is set to priority 250. I have another task that I've set
>> to a priority of 235. When I have the shell in the build, that priority
>> 235 task appears to pend indefinitely with the shell reporting state =
>> "TIME" and I don't know where it would be pending. The task is accessing
>> NOR drivers. But just by running the shell command, releases that priority
>> 235 task. In fact, any command releases it. Whether its a valid command
>> or not. But if I remove the shell from the build, everything is fine. The
>> task doesn't pend. It executes as it should. Did I miss something in the
>> documentation regarding integration of the shell? Is there something we
>> are or are not supposed to do when the shell is integrated?
> I'm off today and this is from my phone.
> TIME should indicate that the task is sleeping. Assuming these are not
> POSIX thread priority The priority 235 task has to be blocked or the shell
> task won't run at all. So anytime your shell task runs, the others should
> be blocked.
> --joel
>> *Mathew Benson*
>> CEO | Chief Engineer
>> Windhover Labs, LLC
>> 832-640-4018
>> www.windhoverlabs.com
>> users mailing list
>> users at rtems.org
*Mathew Benson*
Windhover Labs, LLC
832-640-4018
URL: <http://lists.rtems.org/pipermail/users/attachments/20191101/971777e9/attachment.html>
