Partitioned scheduling issue on Raspberry Pi 2
Ebenezer ebbys89 at gmail.com
Mon Nov 4 10:33:50 UTC 2019
Hello Sebastian
I have modified my code as per your suggestion and it works now. Thank
you very much.
Best regards
Ebenezer
On Mon, 28 Oct 2019 at 13:39, Sebastian Huber
> On 28/10/2019 13:25, Ebenezer wrote:
> > Thanks for your reply. I have attached the program that fails with
> > partitioned EDF_SMP configuration.
> RTEMS_SCHEDULER_EDF_SMP(sch0, 1);
> RTEMS_SCHEDULER_EDF_SMP(sch1, 1);
> RTEMS_SCHEDULER_EDF_SMP(sch2, 1);
> RTEMS_SCHEDULER_EDF_SMP(sch3, 1);
> This configuration cannot work due to:
> > I will try RTEMS_SCHEDULER_EDF_SMP(name,CONFIGURE_MAXIMUM_PROCESSORS)
> > on all the four scheduler instances and see if that works.
