File system deadlock troubleshooting
Mathew Benson mbenson at windhoverlabs.com
Thu Oct 10 04:05:26 UTC 2019
I enabled RTEMS_RAMDISK_TRACE.  That appears to be dead code in my build.
Change didn't do anything.  I checked the symbol table and none of those
functions are in my build.  The actual ram disk driver is in a different
location and didn't have a trace equivalent.  Is there another way to get a
trace from ramdisk?
On Wed, Oct 9, 2019 at 6:01 PM Chris Johns <chrisj at rtems.org> wrote:
> On 10/10/19 6:23 am, Mathew Benson wrote:
> > I added the tracerfs command to the shell.  Not sure why that's not
> already
> > there.
> The command is not in the shell directory and I did not add it to the
> config for
> the shell. Maybe is should be. I am not sure.
> > I enabled all with "tracerfs set all".  It took a while, but I did run
> > into the problem.  The end of the log is below.  Can you see what the
> kernel is
> > trying to do and what its waiting on from this?  It's going to be a
> while,
> > reading through kernel code, to understand exactly what this means.
> Thank you for this. I am travelling from tomorrow for a while. I will try
> and
> have a look while in transit if I can.
> Chris
*Mathew Benson*
CEO | Chief Engineer
Windhover Labs, LLC
832-640-4018
www.windhoverlabs.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20191009/2312251e/attachment-0001.html>
