installing Doorstop on macOS (for RTEMS use)
Fri Oct 11 20:40:23 UTC 2019
On Thu, Oct 10, 2019 at 8:34 AM Andrew Butterfield
<Andrew.Butterfield at scss.tcd.ie> wrote:
> Dear RTEMS Users,
>  Sebastian Huber asked me to check the availability of Doorstop (https://pypi.org/project/doorstop/) for macOS, and to report my experience on this mailing list.
>  It is planned to use this for RTEMS requirements in the RTEMS qualification project.
I would like to clarify and request confirmation that the use of
Doorstop tools will not be required for "casual" RTEMS users. It will
be necessary for RTEMS maintainers and for users who want to be
involved in the pre-certification effort. Correct?
> It turned out to install really easily on my machine, in few 10s of seconds
> The following is a record of my system setup w.r.t. python,
> and the installation process.
> Hardware/OS: MacBook Pro, 2.8Ghz i7, 16GB ram, 500GB flash, macOS 10.14.6
> python state:
> ~> which python
> /usr/local/bin/python
> ~> python --version
> Python 2.7.16
> ~> which python3
> /usr/local/bin/python3
> ~> python3 --version
> Python 3.7.4
> ~> which pip
> /usr/local/bin/pip
> ~> pip --version
> pip 19.0.3 from /usr/local/lib/python2.7/site-packages/pip (python 2.7)
> ~> which pip3
> /usr/local/bin/pip3
> ~> pip3 --version
> pip 19.1.1 from /usr/local/lib/python3.7/site-packages/pip (python 3.7)
> Both pythons are 'brew' versions. Chris Johns said we should only use
> the native installed versions. However other tools I may choose to used
> often need to be installed using 'brew' and you would be amazed how many
> of those have python as a (brew) dependency.
> Looking in /System/Library/Frameworks/Python.framework/Versions
> we find folders 2.3     2.5     2.6     2.7     Current
> Current contains 2.7.10
> Attempt 1 - use the 'brew' versions
> >pip3 install doorstop
> ------- log -----
> Collecting doorstop
>   Downloading https://files.pythonhosted.org/packages/d3/20/315248b287ee6b3055d23d02c00801a38f44a0baf4ebd225c63bf66c0812/doorstop-1.6-py3-none-any.whl (276kB)
>      |████████████████████████████████| 276kB 2.6MB/s
> Collecting Markdown<3,>=2 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/6d/7d/488b90f470b96531a3f5788cf12a93332f543dbab13c423a5e7ce96a0493/Markdown-2.6.11-py2.py3-none-any.whl (78kB)
>      |████████████████████████████████| 81kB 20.2MB/s
> Collecting plantuml-markdown<4.0,>=3.0 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/9a/62/f23ad5e2cf3b196d253cba258bc97862de3057d4861c52df485be11ca060/plantuml_markdown-3.1.3-py3-none-any.whl
> Requirement already satisfied: PyYAML<6.0,>=5.1 in /usr/local/lib/python3.7/site-packages (from doorstop) (5.1)
> Collecting openpyxl<3.0,>=2.6 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/d6/26/eb28e975b7a37aad38d7ec4f7a0f652bdee6ecf36e6bd06f473c5af9b87b/openpyxl-2.6.4.tar.gz (173kB)
>      |████████████████████████████████| 174kB 33.4MB/s
> Collecting pyficache==0.3.1 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/5a/97/859698b53eea27b92746105170417d881bfe99304626efc770d505323be4/pyficache-0.3.1.tar.gz
> Collecting mdx_outline<2.0.0,>=1.3.0 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/01/88/2c978ced5a64a5fb6be8a788bac64e2cc5eaf603535ccec2b51cd98a388c/mdx_outline-1.3.0.tar.gz
> Collecting bottle==0.12.13 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/bd/99/04dc59ced52a8261ee0f965a8968717a255ea84a36013e527944dbf3468c/bottle-0.12.13.tar.gz (70kB)
>      |████████████████████████████████| 71kB 20.0MB/s
> Collecting python-markdown-math==0.6 (from doorstop)
>   Downloading https://files.pythonhosted.org/packages/7c/81/2c86570437821d77b90a6d939d54e11b507b71785850840a5e56d8febeca/python_markdown_math-0.6-py2.py3-none-any.whl
> Requirement already satisfied: requests<3,>=2 in /usr/local/lib/python3.7/site-packages (from doorstop) (2.22.0)
> Collecting plantuml (from plantuml-markdown<4.0,>=3.0->doorstop)
>   Downloading https://files.pythonhosted.org/packages/1e/92/0754877e9f3752216717f53ef3c66b238ffaa4043402f4ecde1173c8d0d5/plantuml-0.2.1-py3-none-any.whl
> Collecting jdcal (from openpyxl<3.0,>=2.6->doorstop)
>   Downloading https://files.pythonhosted.org/packages/f0/da/572cbc0bc582390480bbd7c4e93d14dc46079778ed915b505dc494b37c57/jdcal-1.4.1-py2.py3-none-any.whl
> Collecting et_xmlfile (from openpyxl<3.0,>=2.6->doorstop)
>   Downloading https://files.pythonhosted.org/packages/22/28/a99c42aea746e18382ad9fb36f64c1c1f04216f41797f2f0fa567da11388/et_xmlfile-1.0.1.tar.gz
> Collecting coverage (from pyficache==0.3.1->doorstop)
>   Downloading https://files.pythonhosted.org/packages/93/07/8302163cdbe2008441aa69f2119750110fde15ffd8a56a687311b143365a/coverage-4.5.4-cp37-cp37m-macosx_10_13_x86_64.whl (181kB)
>      |████████████████████████████████| 184kB 31.0MB/s
> Requirement already satisfied: pygments>=2.0 in /usr/local/lib/python3.7/site-packages (from pyficache==0.3.1->doorstop) (2.4.0)
> Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests<3,>=2->doorstop) (2.8)
> Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests<3,>=2->doorstop) (2019.3.9)
> Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.7/site-packages (from requests<3,>=2->doorstop) (3.0.4)
> Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests<3,>=2->doorstop) (1.25.2)
> Collecting httplib2 (from plantuml->plantuml-markdown<4.0,>=3.0->doorstop)
>   Downloading https://files.pythonhosted.org/packages/d2/84/f97b9efdb17c9b73e133bdbf2b4bfd09cd0be655e36e3ee3c4bec9095048/httplib2-0.14.0-py3-none-any.whl (94kB)
>      |████████████████████████████████| 102kB 23.6MB/s
> Building wheels for collected packages: openpyxl, pyficache, mdx-outline, bottle, et-xmlfile
>   Building wheel for openpyxl (setup.py) ... done
>   Stored in directory: /Users/butrfeld/Library/Caches/pip/wheels/58/1d/e3/7c7ee57db55ac00dd5c4632287d8401cdd08ed59c965306f9c
>   Building wheel for pyficache (setup.py) ... done
>   Stored in directory: /Users/butrfeld/Library/Caches/pip/wheels/ea/6d/01/c61eda6fd06bd626345626d0bb00621c4ff49c09231e760be4
>   Building wheel for mdx-outline (setup.py) ... done
>   Stored in directory: /Users/butrfeld/Library/Caches/pip/wheels/07/89/02/c9ce27a8c12df62b57aed406e996663b3394eec9e9bc7897dd
>   Building wheel for bottle (setup.py) ... done
>   Stored in directory: /Users/butrfeld/Library/Caches/pip/wheels/76/a0/b4/2a3ee1a32d0506931e558530258de1cc04b628eff1b2f008e0
>   Building wheel for et-xmlfile (setup.py) ... done
>   Stored in directory: /Users/butrfeld/Library/Caches/pip/wheels/2a/77/35/0da0965a057698121fc7d8c5a7a9955cdbfb3cc4e2423cad39
> Successfully built openpyxl pyficache mdx-outline bottle et-xmlfile
> Installing collected packages: Markdown, httplib2, plantuml, plantuml-markdown, jdcal, et-xmlfile, openpyxl, coverage, pyficache, mdx-outline, bottle, python-markdown-math, doorstop
> Successfully installed Markdown-2.6.11 bottle-0.12.13 coverage-4.5.4 doorstop-1.6 et-xmlfile-1.0.1 httplib2-0.14.0 jdcal-1.4.1 mdx-outline-1.3.0 openpyxl-2.6.4 plantuml-0.2.1 plantuml-markdown-3.1.3 pyficache-0.3.1 python-markdown-math-0.6
> ------- end ----- took several seconds
> doorstop --help works
> I succesfully completed their mini-tutorial introduction.
> Regards, Andrew Butterfield
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Foundations & Methods Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                          http://www.scss.tcd.ie/Andrew.Butterfield/
> users mailing list
> users at rtems.org
