Partitioned scheduling issue on Raspberry Pi 2
Ebenezer
ebbys89 at gmail.com
Fri Oct 25 13:29:06 UTC 2019
Hello everyone
I am facing some issues while using partitioned scheduling on
RaspberryPi2. I want to run one scheduler instance on each core (ie. 4
Scheduler instances in total). I can configure and run
PRIORITY_AFFINITY_SMP, PRIORITY_SMP and SIMPLE_SMP scheduler
algorithms into partitions/clusters without any problem. When I tried
to configure EDF_SMP scheduler algorithm in the same manner, the 3rd
instance of the scheduler is not getting assigned to Core 2. But the
other 3 instances of EDF_SMP schedulers are getting assigned to proper
cores.
I used rtems_scheduler_get_processor_set to verify scheduler
assignments and i get the following CPUSET values
Scheduler 1 CPUSET: 0001
Scheduler 2 CPUSET: 0010
Scheduler 3 CPUSET: 100010001000111101000
Scheduler 4 CPUSET: 1000
I am using RTEMS 5 SMP. Is there a way to solve this issue?
Thanks in advance
Ebenezer
