Partitioned scheduling issue on Raspberry Pi 2
Ebenezer ebbys89 at gmail.com
Mon Oct 28 12:25:48 UTC 2019
Thanks for your reply. I have attached the program that fails with
partitioned EDF_SMP configuration.
I will try RTEMS_SCHEDULER_EDF_SMP(name,CONFIGURE_MAXIMUM_PROCESSORS)
on all the four scheduler instances and see if that works.
Best regards
Ebenezer
On Mon, 28 Oct 2019 at 07:12, Sebastian Huber
> Hello Ebenezer,
> a self-contained example program which reproduces this issue would be
> helpful.
> In the RTEMS_SCHEDULER_EDF_SMP(name, max_cpu_count) configuration
> define, the max_cpu_count must be CONFIGURE_MAXIMUM_PROCESSORS.
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20191028/52862221/attachment.bin>
