Help for using simulator for Beagleboard
Utkarsh Rai utkarsh.rai60 at gmail.com
Thu Oct 31 18:13:10 UTC 2019
Thank you for your suggestion, I will look into it.
On Thu, Oct 31, 2019 at 3:23 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Oct 30, 2019 at 4:01 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 31/10/19 6:44 am, Utkarsh Rai wrote:
>> > I am trying to get my hands dirty with RTEMS using Beagleboard. I have
>> been
>> > successful in building the toolchain, RTEMS, the beagle BSPs, and the
>> test
>> > suites.
>> Excellent and well done.
>> > As of now, I do not have any physical hardware to run and test the BSPs,
>> > it would be very kind of you if I can get a few indicators for setting
>> up the
>> > simulator for Beagleboard and testing the BSPs on it.
>> Qemu supports some of beagle boards. I suggest you investigate qemu and
>> running
>> on it.
> qemu-system-arm -M ? will list the "models" supported. I don't see the
> Beagle in the
> qemu I have from the qemu.bset. qemu4.bset might have it. I don't know if
> it is in
> the mainline qemu.
> People used to use the Linaro distribution qemu to get this.
> --joel
>> Chris
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191031/cadba00c/attachment.html>
