shell output
Mathew Benson mbenson at windhoverlabs.com
Thu Oct 31 18:43:31 UTC 2019
is there any documentation that explains the actual output of the shell
commands?  For example, the documentation for the task command says how to
run it, and gives the following sample output:
SHLL [/] # task
ID       NAME                 SHED PRI STATE  MODES    EVENTS WAITINFO
0a010001 UI1                  UPD  254 EV     P:T:nA   NONE
0a010002 SHLL                 UPD  100 READY  P:T:nA   NONE
But doesn't actually explain what the data in the columns mean.  What do
the following "STATE" values mean:  EV, SIG:IS, READY, MSG, SEM, and TIME?
What do the MODES mean?  Same question for the "sema" command output.
*Mathew Benson*
CEO | Chief Engineer
Windhover Labs, LLC
832-640-4018
www.windhoverlabs.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20191031/7c3c0224/attachment.html>
