Three chip erc32 Re: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Jiri Gaisler
jiri at gaisler.se
Tue Sep 3 07:14:26 UTC 2019
Hmm, maybe clock driver code has been changed during the years to read
or write some register bits that are illegal on the 3-chip ERC32. This
would cause a trap to error mode and most likely a watchdog reset. I
quickly looked through the ERC32 clock driver code but could not see
anything obvious. It could also be an ERC32 interrupt driver issue -
enabling interrupts seems to trigger the problem. I will try to run
ticker on an old version of sis that did some more checks for the 3-chip
version ...
On 9/3/19 12:57 AM, Joel Sherrill wrote:
> Jiri does this ring a bell with the old Tharsys board and 3 chip erc32?
> On Mon, Sep 2, 2019, 5:09 PM Michel Macena <mmacena.eng at gmail.com
> <mailto:mmacena.eng at gmail.com>> wrote:
> It is the ERC 32 chipset version (TSC691, TSC692 and TSC693
> units), The Board was manufactured by Tharsys, a french company,
> but it does not
> exist anymore. The board manual dates from 2000.
> Em sex, 30 de ago de 2019 às 17:53, Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> escreveu:
> On Fri, Aug 30, 2019, 11:35 AM Michel Macena
> <mmacena.eng at gmail.com <mailto:mmacena.eng at gmail.com>> wrote:
> Thanks for the answer, but the ticker sample program
> has this macro in his system.h header. I can compile a program
> with this macro but when I load it, the board just
> ignores it an then reset. If I change the
> macro for the opposite one ("does not need the clock
> driver") the program just works, except that I can't
> use any time related routine. Also without the clock drive
> driver enabled I can't communicate with the board (send
> and receive data).
> I understand that the Macro enables the clock drive but
> how this happens ? It changes a register value in the chip ?
> Setting that macro adds the clock driver to the set of
> statically installed device drivers. The code is in
> bsps/sparc/erc32/clock. It uses a timer on the erc32.
> Check that it survives initialising the clock and gets the
> interrupt ok.
> This isn't something I have heard of before. Is this a very
> early erc32? Just wondering with nothing specific in mind.
> --joel
> Em sex, 30 de ago de 2019 às 03:21, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> escreveu:
> On 30/08/2019 19:09, Michel Macena wrote:
> > I still have the issue with the macro #define
> > CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER. I tried
> > a different version of RTEMS but It didn't work. Can
> someone explain me
> > how this macro works? So I can
> > try to figure out some patch or fix for my hardware.
> This configuration option enables the clock driver.
> I would run first the RTEMS test suite on your target.
> For example start
> with the ticker sample program.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> Diese Nachricht ist keine geschäftliche Mitteilung im
> Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190903/5a99062b/attachment-0001.html>
