Msys2 on Windows 10
    Jeff Mayes
    Jeff.Mayes at OARcorp.com
    Wed Sep  4 19:08:05 UTC 2019
Hi
I have a fresh install of Windows 10, with updates.  Then installed MSYS2 as instructed here:
https://docs.rtems.org/branches/master/user/hosts/windows.html#msys2
Fetched the RSB, and then tried to build rtems-sparc tools, like this...
$ ../source-builder/sb-set-builder --prefix=/home/mayes/dev/rtems/5 5/rtems-sparc
RTEMS Source Builder - Set Builder, 5 (b45df48a51bc)
Build Set: 5/rtems-sparc
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-w64-mingw32-1
building: expat-2.1.0-x86_64-w64-mingw32-1
sizes: expat-2.1.0-x86_64-w64-mingw32-1: 9.229MB (installed: 2.037MB)
cleaning: expat-2.1.0-x86_64-w64-mingw32-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.xml
config: tools/rtems-gdb-8.3-1.cfg
error: shell macro failed: sh -c "/mingw64/bin/python2-config --ldflags | awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"*";}'": 1: }/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}': -c: line 0: unexpected EOF while looking for matching `''
}/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}': -c: line 1: syntax error: unexpected end of file
Build FAILED
Build Set: Time 0:07:19.564000
Build FAILED
This happens when using Python3 and also when using Python2.
Any ideas?
Thanks
Jeff
URL: <http://lists.rtems.org/pipermail/users/attachments/20190904/056d78d6/attachment-0001.html>
