Msys2 on Windows 10
jameszxj
jameszxj at gmail.com
Thu Sep 5 08:15:07 UTC 2019
Hi
I encountered this error , I have created a ticket about it.
#3783
------------------ Original ------------------
Date: Thu, Sep 5, 2019 06:30 AM
To: "Jeff Mayes"<Jeff.Mayes at OARcorp.com>;"RTEMS Users"<rtems-users at rtems.org>;
Subject: Re: Msys2 on Windows 10
On 5/9/19 5:08 am, Jeff Mayes wrote:
> Hi
> I have a fresh install of Windows 10, with updates. Then installed MSYS2 as
> instructed here:
> https://docs.rtems.org/branches/master/user/hosts/windows.html#msys2
> Fetched the RSB, and then tried to build rtems-sparc tools, like this…
> $ ../source-builder/sb-set-builder --prefix=/home/mayes/dev/rtems/5 5/rtems-sparc
> RTEMS Source Builder - Set Builder, 5 (b45df48a51bc)
> Build Set: 5/rtems-sparc
> Build Set: 5/rtems-autotools.bset
> Build Set: 5/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-w64-mingw32-1
> building: expat-2.1.0-x86_64-w64-mingw32-1
> sizes: expat-2.1.0-x86_64-w64-mingw32-1: 9.229MB (installed: 2.037MB)
> cleaning: expat-2.1.0-x86_64-w64-mingw32-1
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-w64-mingw32-1.xml
> config: tools/rtems-gdb-8.3-1.cfg
> error: shell macro failed: sh -c "/mingw64/bin/python2-config --ldflags | awk
> 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print
> "lib"substr($i,3)"*";}'": 1:
> }/python/{for(i=1;i<NF;++i)if(match($i,.*lpython.*)) print libsubstr($i,3)*;}':
> -c: line 0: unexpected EOF while looking for matching `''
> -c: line 1: syntax error: unexpected end of file
> Build FAILED
> Build Set: Time 0:07:19.564000
> Build FAILED
> This happens when using Python3 and also when using Python2.
> Any ideas?
Looks like I broken something. Please raise a ticket against 5 and assign to me.
Thanks
> Thanks
> Jeff
> users mailing list
> users at rtems.org
users mailing list
users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190905/4f48d544/attachment.html>
