symbol resolve between the two RAP files
jameszxj
jameszxj at gmail.com
Fri Sep 20 01:06:33 UTC 2019
when use dynamic load, RAP module should have unresolved symbol most time,
And maybe unresolved symbols scatter over 2 or more files, one BaseImage is not enough.
So I suggest rtems-ld just throw a warning not a error.
Another suggestion is option -e(--entry) is not essential. We just use dlsym to find a entry.(or there is another way to run entry?)
------------------ Original ------------------
Date: Thu, Sep 12, 2019 11:22 AM
To: "jaeho jo"<hot486two at gmail.com>;"users"<users at rtems.org>;
Subject: Re: symbol resolve between the two RAP files
On 10/9/19 10:23 am, jaeho jo wrote:
> I wonder if I can resolve the symbol between the two RAP files for dynamic load.
> ex)
> a.c. / b.c. / main.c.
> a.c. -> a.rap
> - define 'a_test_func()'
> b.c. -> b.rap
> - use 'a_test_func()'
> main.c -> BaseImage
> Attempting to generate b.c. as b.rap using rtems-ld, an error occurs
> $ rtems-ld -b BaseImage -e b_main b.o -o b.rap
> => error: b.o: symbol not found: a_test_func
> I already know why this problem occurs, since BaseImage does not have a symbol
> for 'a_test_func'>
> Is there a way to solve this? Or is it impossible at all?
Have you tried ...
$ rtems-ld -b BaseImage -e b_main a.o b.o -o z.rap
You should be able to load modules with an unresolved error and when the module
with the symbol is loaded it is resolved.
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20190920/208dce83/attachment.html>
