CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
    Sebastian Huber
    Mon Sep  2 05:41:06 UTC 2019
On 30/08/2019 18:33, Michel Macena wrote:
> Thanks for the answer, but the ticker sample program
> has this macro in his system.h header.
In case the ticker sample program doesn't run properly on your ERC32
board, then it makes no sense to start application development. You have
to figure out why this test program fails. There is probably an issue in
the clock driver, the clock driver setup or the overall low level system
setup. You can use GRMON to debug this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
