libbsd VLAN tagging
Christian Mauderer
oss at c-mauderer.de
Wed Apr 22 09:52:07 UTC 2020
On 22/04/2020 09:47, Matthew J Fletcher wrote:
> Hi,
> How would an application using libbsd add VLAN tags to transmitted
> frames so an external switch chip could process them ?
> Is there an application / libbsd interface for this or does it require
> the driver to be modified.
Hello Matthew,
in theory it should be the same interface like on FreeBSD:
https://www.freebsd.org/doc/handbook/network-vlan.html
But as far as I know it needs driver support:
https://www.freebsd.org/cgi/man.cgi?query=vlan&sektion=4&manpath=freebsd-release-ports
Best regards
Christian
> regards
> Matthew J Fletcher
> users mailing list
> users at rtems.org
