Interested in contributing to Beaglebone BSP
James Fitzsimons james.fitzsimons at gmail.com
Sun Apr 26 10:05:22 UTC 2020
Hi Christian,
Thanks for your reply.
On Wed, 22 Apr 2020 at 23:29, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello James,
> On 20/04/2020 13:13, James Fitzsimons wrote:
> > I am interested in adding support for the eQEP (Enhanced Quadrature
> > Encoder Pulse Module) which I am using to decode the quadrature encoders
> > on my motors.
> That one isn't implemented yet and I don't know of any current work on
> it. So feel free to go ahead.
Thanks for the encouragement - I will start with the eQEP drivers.
> I will eventually also need support for the ADC, PRU (I see some work
> > has already been done on that by a GSoC project),
> There has been some work on PRU. I'm not entirely sure about ADC.
> > and ideally the TI
> > WiLink 8 WL1835MOD wireless chipset - although I realise that might be
> > extremely difficult.
> That depends: What kind of interface is used for that? And is the chip
> already supported in FreeBSD?
I have done a bit of research and can't find any FreeBSD support for it.
There are obviously linux drivers but I realise these are not suitable for
porting to RTEMS
> If it is an USB interface and it is supported in FreeBSD adding it
> shouldn't be much work. If it is an SDIO it will get a bit more
> difficult but still possible in a decent time frame. If FreeBSD doesn't
> know anything about it you will have a really hard time. WLAN drivers
> are _very_ complex and the need a lot of detail knowledge about the
> chipset and the regulations.
I'm pretty sure it uses an SDIO interface, but as you say without the
FreeBSD support it may be a bit of a long shot.
> > Are drivers for these features something that would be welcome in the
> > BBB BSP, and if so any tips for getting started?
> Of course. Peripheral drivers are nearly always welcome.
> For the PRU you might should contact the GSoC student working on the
> topic. For WLAN: Please check the interface and FreeBSD support. I don't
> know exactly what the eQEP does. But if there is a FreeBSD driver for it
> you might want to check that one too and maybe port it via libbsd
> (except the eQEP is a really simple module and it's a lot simpler to
> write the driver yourself in the BSP)
I'll make a start on the eQEP module (quadrature decoder for reading
encoders) and if that goes well I'll reach out to Nils Hölscher about the
PRU work.
Thanks and regards,
James Fitzsimons
URL: <http://lists.rtems.org/pipermail/users/attachments/20200426/8323f5c5/attachment.html>
