RTEMS tasks timesliced instead of running to completion. TIMESLICE flag is not active!
Joel Sherrill
joel at rtems.org
Thu Apr 30 15:24:38 UTC 2020
On Thu, Apr 30, 2020, 10:14 AM Fernando Domínguez Pousa <fdpousa at gmv.com>
wrote:
> Hello,
> I am executing a program which executes four different task with testing
> operations. These tasks were created and launched in this way:
> status = rtems_task_create(Task_name[i], (rtems_task_priority) 2,
> RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
> (i%2) == 0 ? RTEMS_FLOATING_POINT : RTEMS_DEFAULT_ATTRIBUTES,
> &Task_id[i]);
> status = rtems_task_start(Task_id[i], (i%2) == 0 ? Task1_EntryPoint :
> Task2_EntryPoint, i);
> As you can see all task are created with the same priority, and launched
> one after the other inside a for loop. They are configured in default
> modes, so time slicing is disabled by default (all mode bits are 0). This
> result would be expected due to each task would run-to-completion because
> all tasks have the same priority:
> The expected result:
> [MAIN] Waiting for testing tasks to complete...
> [TASK 0] Starting...
> [TASK 0] Computed the correct floating point result.
> [TASK 1] Starting...
> [TASK 1] Computed the correct integer result.
> [TASK 2] Starting...
> [TASK 2] Computed the correct floating point result.
> [TASK 3] Starting...
> [TASK 3] Computed the correct integer result.
> [MAIN] All testing tasks completed.
> Nevertheless, using RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_MODES |
> RTEMS_TIMESLICE or RTEMS_DEFAULT_MODES | RTEMS_NO_PREEMPT either as
> rtems_mode, the result is always the same.
> The actual result:
> At RTEMS API Guide:
> The timeslicing component is used by the RTEMS scheduler to determine how
> the processor is allocated to tasks of equal priority. If timeslicing is
> enabled (RTEMS_TIMESLICE), then RTEMS will limit the amount of time the
> task can execute before the processor is allocated to another ready task of
> equal priority.
> *The length of the timeslice is application dependent and specified in the
> Configuration Table. If timeslicing is disabled (**RTEMS_NO_TIMESLICE**),
> then the task will be allowed to execute until a task of higher priority is
> made ready. *However I have not any task with higher priority, Init task
> priority is lower.
> If RTEMS_NO_PREEMPT is selected, then the timeslicing component is
> ignored by the scheduler.
> How can I execute this tasks in a run to completion fashion for same
> priority tasks? Task 0 starts and ends, then Task1 starts and ends… etc,
There are many things that could be happening. Can you post the program?
> Regards,
> Fer.
> P Please consider the environment before printing this e-mail.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200430/e8243506/attachment-0001.html>
