BSP testing for rtems
Chris Johns
chrisj at rtems.org
Sat Aug 8 00:58:29 UTC 2020
On 8/8/20 1:38 am, Zacchaeus Liang wrote:
> Hello,
> I'm currently trying to build and test rtems, then i'll be trying to build the
> hello world app. How do I test the bsp for the pc386 using qemu? Does anyone
> know where the testing script for pc386-qemu? Also, I heard that the rtems-test
> executable is deprecated from the qemu page.
The `rtems-test` command should have a way to evoke qemu for the PC BSP. If you
add `--trace` the actual qemu command will be printed.
> *sim-scripts and rtems-testing is obsolete, please refer to the User Manual's
> Testing section*
The section is:
https://docs.rtems.org/branches/master/user/testing/index.html
