BSP testing and building applications
Zacchaeus Liang zliang111 at gmail.com
Sun Aug 9 20:30:50 UTC 2020
Hello,
I'm Zack and I'm currently finishing up my university degree in comp sci.
I'm really interested in aviation and aerospace systems. I want to get into
rtems to learn more about rtos and contribute to rtems !
Currently I'm trying to build rtems and test and bsp. Hoping to then
contribute. I followed one of you GSOC student's tutorials and tried to go
ahead. I'm trying to build the test the bsp right now.
here is his blog post
https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
I tried to run the bsp testing like this and it says the ini file is not
found.  Is this the right bsp argument?  After this i'm going to try to
build an application and would like to know the right path to install it.
Any tips on looking for easy things to learn to patch? Thanks in advance i
know it's a handful for questions!
zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/rtems/kernels-5/pcp-386$
rtems-test --rtems-bsp=i386-rtems5
--rtems-tools=$HOME/development/rtems/5
RTEMS Testing - Tester, 5.0.not_released
 Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
--rtems-tools=/home/zakonrockets/development/rtems/5 Host: Linux
zakonrockets-Inspiron-15-7000-Gaming 5.3.0-62-generic #56-Ubuntu SMP
Tue Jun 23 11:20:52 UTC 2020 x86_64 Python: 3.7.5 (default, Apr 19
2020, 20:18:17) [GCC 9.2.1 20191008]Host:
Linux-5.3.0-62-generic-x86_64-with-Ubuntu-19.10-eoan (Linux
Tue Jun 23 11:20:52 UTC 2020 x86_64 x86_64)error: cannot find bsp
configuration file: i386-rtems5.ini
this is the output of my testing. Thanks for all the help!!
Zack
URL: <http://lists.rtems.org/pipermail/users/attachments/20200809/4e3934a6/attachment.html>
