users Digest, Vol 167, Issue 8
Zacchaeus Liang zliang111 at gmail.com
Tue Aug 11 00:24:36 UTC 2020
I tried to add the prefix and i had the prefix  with this
rtems-test --rtems-bsp=i386-rtems5 --rtems-tools=$HOME/development/rtems/5
--rtems-prefix=$HOME/development/rtems/5
i get the same error. Was the prefix correct based on the instructions?
Thanks
zack
Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <niteesh.gs at gmail.com>
ha scritto:
> Hello,
>> Hello,
>> I'm Zack and I'm currently finishing up my university degree in comp sci.
>> I'm really interested in aviation and aerospace systems. I want to get
>> into
>> rtems to learn more about rtos and contribute to rtems !
>> Currently I'm trying to build rtems and test and bsp. Hoping to then
>> contribute. I followed one of you GSOC student's tutorials and tried to go
>> ahead. I'm trying to build the test the bsp right now.
>> here is his blog post
>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> I tried to run the bsp testing like this and it says the ini file is not
>> found.  Is this the right bsp argument?  After this i'm going to try to
>> build an application and would like to know the right path to install it.
>> Any tips on looking for easy things to learn to patch? Thanks in advance i
>> know it's a handful for questions!
>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming
>> :~/development/rtems/kernels-5/pcp-386$
>> RTEMS Testing - Tester, 5.0.not_released
>>  Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
>> --rtems-tools=/home/zakonrockets/development/rtems/5 Host: Linux
>> zakonrockets-Inspiron-15-7000-Gaming 5.3.0-62-generic #56-Ubuntu SMP
>> Tue Jun 23 11:20:52 UTC 2020 x86_64 Python: 3.7.5 (default, Apr 19
>> 2020, 20:18:17) [GCC 9.2.1 20191008]Host:
>> Linux-5.3.0-62-generic-x86_64-with-Ubuntu-19.10-eoan (Linux
>> Tue Jun 23 11:20:52 UTC 2020 x86_64 x86_64)error: cannot find bsp
>> configuration file: i386-rtems5.ini
>> My guess here is that you might have missed the install step. In your BSP
> directory
> you should execute the* make install *If you have already done this step
> then I think
> the issue might be in the prefix directory. I guess you might have given a
> custom
> prefix path. In this case, you must explicitly provide the prefix using
> --rtems-prefix=<PATH>
> Thanks,
> Niteesh.
>> this is the output of my testing. Thanks for all the help!!
>> Zack
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.rtems.org/pipermail/users/attachments/20200809/4e3934a6/attachment-0001.html
URL: <http://lists.rtems.org/pipermail/users/attachments/20200810/7d2caf39/attachment-0001.html>
