Task unexpected restart when sending bytes to usart.
Daniel Li ludvig.lee at gmail.com
Fri Aug 28 02:59:39 UTC 2020
Hi Joel
 I think you are right, it is a complete reset.  I don't know the reason
for the system reset. My test code is as below. System will reset after
about 40min.
#include <termios.h>
#include <fcntl.h>
#include <unistd.h>
#include <rtems/error.h>
#include <rtems/libio.h>
#include <rtems/stackchk.h>
#include <libchip/chip.h>
#include <bsp.h>
#define PORT                "/dev/ttyUART1"
#define PIN_UART1_RXD
       {PIO_PA5C_URXD1, PIOA, ID_PIOA, PIO_PERIPH_C, PIO_DEFAULT}
#define PIN_UART1_TXD
       {PIO_PA4C_UTXD1, PIOA, ID_PIOA, PIO_PERIPH_C, PIO_DEFAULT}
#define PIN_LED_0
           {PIO_PC9,        PIOC, ID_PIOC, PIO_OUTPUT_1, PIO_DEFAULT}
const Pin pins[] = { PIN_UART1_RXD, PIN_UART1_TXD, PIN_LED_0 };
rtems_task task_send( rtems_task_argument task_index )
  char* send_string =
"0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789"
; /* character count : 400 */
  int index = 1;
  rtems_status_code sc = rtems_termios_bufsize( 512, 512, 512 );
  if (sc > 0) {
    perror("rtems_termios_bufsize(): failed \n");
  int fd = open(PORT, O_RDWR);
  if (fd < 0) {
    perror("open(): failed to open /dev/ttyUART1 \n");
  while (1) {
    int len = write(fd, send_string, 200);
    if (len < 0) {
      perror("write(): failded to write\n");
      close(fd);
      exit(-1);
    (void) rtems_task_wake_after( rtems_clock_get_ticks_per_second() / 20
rtems_task task_led( rtems_task_argument task_index )
  while(1) {
    if (PIO_GetOutputDataStatus(&pins[2]))
      PIO_Clear(&pins[2]);
    else
      PIO_Set(&pins[2]);
    (void) rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
rtems_task Init( rtems_task_argument argument )
  rtems_id   task_id[ 4 ];
  rtems_name task_name[ 4 ];
  task_name[ 1 ] = rtems_build_name( 'S', 'N', 'D', ' ' );
  task_name[ 2 ] = rtems_build_name( 'L', 'E', 'D', ' ' );
  PIO_Configure(pins, PIO_LISTSIZE(pins));
  puts("This is the Init Thread.\n");
  (void) rtems_task_create(
    task_name[ 1 ], 1, RTEMS_MINIMUM_STACK_SIZE * 4, RTEMS_DEFAULT_MODES,
    RTEMS_DEFAULT_ATTRIBUTES, &task_id[ 1 ]
    task_name[ 2 ], 2, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
    RTEMS_DEFAULT_ATTRIBUTES, &task_id[ 2 ]
  (void) rtems_task_start( task_id[ 1 ], task_send, 1 );
  (void) rtems_task_start( task_id[ 2 ], task_led, 2 );
  (void) rtems_task_delete( RTEMS_SELF );
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MICROSECONDS_PER_TICK       10000
#define CONFIGURE_TICKS_PER_TIMESLICE         5
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS    10
#define CONFIGURE_INIT_TASK_STACK_SIZE        (2 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_EXTRA_TASK_STACKS           (4 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_MAXIMUM_TASKS               5
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <rtems/confdefs.h>
Thanks
Daniel
On Thu, Aug 27, 2020 at 7:52 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Aug 27, 2020, 2:33 AM Daniel Li <ludvig.lee at gmail.com> wrote:
>> Hello world
>> I'm using RTEMS5 as an uart2udp converter. I'm observing a task restart
>> when I send bytes to uart for a long time ( for 20min @ about 200 bytes/s
>> ), and there is no error reported. I don't know how to overcome, anyone
>> encountered this problem?
> Are you sure it isn't a complete reset? That would make more sense to me
> as a possibility.
>> Thanks
>> Daniel
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200828/266bed1d/attachment-0001.html>
