How to program fine-grained real-time concurrent applications in C or Ada
Mattia Bottaro mattiabottaro9 at gmail.com
Thu Dec 24 20:20:22 UTC 2020
Hello Joe Sherrill and thank you for the quick response.
I'm not sure I understand correctly what you said. According to this
example (<
https://github.com/RTEMS/rtems-examples/blob/master/classic_api/triple_period/tasks.c#L70>),
"'ticks' is don't care ( = does not work);". What should I infer from this
comment?
I've also checked *rtems_task_wake_after*, but it is not what I'm
looking for: I need something semantically similar to Ada's *delay until, *so
*not *a *delay. *That's why neither *clock_nanospleep *is suitable for my
purposes.
Il giorno gio 24 dic 2020 alle ore 18:31 Joel Sherrill <joel at rtems.org> ha
scritto:
> You missed all the directives that use ticks in the Classic API. There is
> rtems_task_wake_after for one. Almost every service that had a delay or
> timeout is in ticks. The length of a tick is configurable in microseconds.
> POSIX has different services and specifies time intervals and delays
> differently. See clock_nanosleep for an example where you can even pick the
> clock source.
> --joel
> On Thu, Dec 24, 2020, 5:13 AM Karel Gardas <karel.gardas at centrum.cz>
> wrote:
>> I'd try to use POSIX API and POSIX timers. Look into testsuites/psx*
>> tests.
>> Cheers,
>> Karel
>> On 12/24/20 11:24 AM, Mattia Bottaro wrote:
>> > Hi everyone, newbie RTEMS here.
>> > I need to develop a multitasking real-time application with RTEMS
>> > (preferably in Ada, but also C solutions are welcomed). I see that I can
>> > use the Classic API
>> > <https://docs.rtems.org/branches/master/c-user/index.html>, but they
>> are
>> > unsuitable to my purposes. As you can read here
>> https://docs.rtems.org/branches/master/c-user/task/directives.html#task-wake-when-wake-up-when-specified
>> > the  rtems_task_wake_when directive is too coarse: "The timing
>> > granularity of this directive is a second.".
>> > I need to work with microseconds-granularity and I cannot find how to
>> do it.
>> > Thanks in advance.
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20201224/04c60d3f/attachment.html>
