simple networking
M. Dodson
md403 at cam.ac.uk
Mon Feb 3 17:10:37 UTC 2020
On 3 Feb 2020, at 16:43, M. Dodson <md403 at cam.ac.uk<mailto:md403 at cam.ac.uk>> wrote:
Hi,
I’m trying to set up a simple example using TCP/IP comms in RTEMS.
I’m using rtems5 and targeting RISC-V (rv64imac_medany).
I’ve tried to follow the RTEMS Networking User Manual. The manual says RTEMS_BSP_NETWORK_DRIVER_ATTACH RTEMS_BSP_NETWORK_DRIVER_NAME should be defined in my bsp.h file, but I don’t see them defined anywhere.
I’ve built RTEMS according to the quick start guide. Do I need to do something differently to build RTEMS for networking use?
Addition:
I’m trying to build these examples with waf and I might simply be confused about the flow.
For example, it’s unclear to me, when using waf, when I would specify --enable-networking.
Thanks,
Mike
URL: <http://lists.rtems.org/pipermail/users/attachments/20200203/da573494/attachment.html>
