Error with Boost scope
Sebastian Huber
Tue Feb 4 13:05:30 UTC 2020
On 04/02/2020 13:44, M. Dodson wrote:
>> On 4 Feb 2020, at 12:32, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 04/02/2020 13:20, M. Dodson wrote:
>>> from /usr/local/include/boost/math/policies/policy.hpp:21,
>> Did you add /usr/local/include to the include path used to build an RTEMS application?
> Yes. And when I cloned and build Boost from source, I added that to my include path.
> Specifically, my waf has:
> includes = [
> '/Users/michaeldodson/projects/rtems_root/boost_1_72_0',
> '/usr/local/include’]
> It seems to be finding the header files just fine, as the errors are associated with a declaration within the header that isn’t in scope.
You should not use standard installation paths of your host system for
header files of the RTEMS target. This may accidentally pull in
undesired header files.
I would look at the pre-processed files (-save-temps -Wp,--dD) to figure
out what happens.
