Linker Problem
Thu Jan 9 06:02:56 UTC 2020
Hello Reuben,
On 08/01/2020 22:48, Fresquez, Reuben Anthony wrote:
> Hello,
> I am currently using Geisler’s RCC 1.2 and RTEMS 4.10. I am getting an
> error after compiling my c files into object files, and then linking
> them together. The error I get is:
> /opt/rtems-4.10/sparc-rtems/leon3/lib/librtemscpu.a(dummy.o):(.data+0x2c):
> undefined reference to `main'
> collect2: ld returned 1 exit status
a likely reason for this error is that you don't have an application
configuration or the configuration is somehow incomplete or inconsistent:
https://docs.rtems.org/branches/master/c-user/configuring_a_system.html
You can look at the linker map file (GCC link option "-Wl,-Map,map.txt")
to figure out what pulled in dummy.o.
> I am using “sparc-rtems-gcc“ to do the linking, and cannot seem to
> figure out how to get around this problem. The file “librtemscpu.a” is
> part of the prebuilt libraries included in the RCC 1.2 distribution, and
> I cannot find any source code for this file to inspect the unresolved
> reference to main. I am wondering if any of you have suggestions about
> solving this issue or maybe have run into the same thing. Please let me
> know.
I guess you can obtain the sources in an extra package. Working without
the RTEMS sources could turn out to be difficult in the long run.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
