make: *** [all-recursive] Error 1
Joel Sherrill
joel at rtems.org
Sun Jan 12 19:19:33 UTC 2020
On Sun, Jan 12, 2020, 12:55 PM Prithvi Chakravarthy <
prithvichakravarthy at gmail.com> wrote:
> I have been trying to build BSP, so far i have completed the second step
> of building the BSP.
> After executing the "make all " command i am getting this output:
> Making all in sparc-rtems5/c
> make[1]: Entering directory
> '/home/prithvi/quick-start/build/b-erc32/sparc-rtems5/c'
> Making all in .
> make[2]: Entering directory
> make[2]: Nothing to be done for 'all-am'.
> make[2]: Leaving directory
> Making all in erc32
> '/home/prithvi/quick-start/build/b-erc32/sparc-rtems5/c/erc32'
> make[2]: *** No rule to make target 'all'. Stop.
> Makefile:289: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> Makefile:410: recipe for target 'all-recursive' failed
What was your configure command? And the end of the configuration output?
When you ran rtems-bootstrap were the RTEMS tools at the front of your PATH?
It should be a simple issue.
--joel
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200112/5d3c2e4b/attachment-0001.html>
