'TIME' task cpuuse
Matthew J Fletcher
amimjf at gmail.com
Tue Jan 14 13:37:04 UTC 2020
Of course without nanoseconds support in the BSP measuring the timer
callback duration is difficult as most calls will be less than a tick.
On Tue, 14 Jan 2020 at 08:41, Matthew J Fletcher <amimjf at gmail.com> wrote:
> Ok,
> So first step is to create a wrapper that all timers fire through, then an
> array to count the number of invocations per timer_id, after that some per
> timer_id time accounting.
> Will let you know if its anything outside my application.
> On Mon, 13 Jan 2020 at 15:01, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Jan 13, 2020 at 8:53 AM Matthew J Fletcher <amimjf at gmail.com>
>> wrote:
>>> Hi,
>>> My application seems to be using around 1/3rd of its total cpu usage in
>>> the 'TIME' task,. is this the task created by rtems_timer_initiate_server()
>> Yes.
>>> What would be the best way to get more information,. are there console
>>> commands that would emit more data, or do i need to instrument my
>>> application to see usage of all rtems_timer_xx callbacks ?
>> rtems_timer_server_xx would be the ones going to the TIME Server.
>> But 1/3 seems quite excessive. I would assume one of your timer server
>> routines is doing something unexpectedly heavy CPU-wise.
>> I don't think there is any instrumentation in the server which would
>> help. Measuring the execution time of each invocation is what comes to
>> mind. My first thought is that this would be a nice debug option for
>> timers. But I am not sure how good this would be for ISR style.
>> --joel
>>> regards
>>> Matthew J Fletcher
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> regards
> Matthew J Fletcher
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20200114/d5dcba48/attachment.html>
