LEON3 RTEMS rc7 Tool Issue
Richard.Glossop at L3Harris.com
Thu Jan 16 14:44:08 UTC 2020
Gaisler just told me the version of gdb (sparc-gaisler-rtems5-gdb) delivered with rc7 was linked incorrectly. Sent me a new version which runs correctly.
From: users <users-bounces at rtems.org> On Behalf Of Schweikhardt, Jens (TSPCE3-TL4)
Sent: Thursday, January 16, 2020 9:40 AM
To: Glossop, Richard (US) @ ISR - SSS - SSTC <Richard.Glossop at L3Harris.com>; users at rtems.org
Subject: [EXT] AW: LEON3 RTEMS rc7 Tool Issue
The rc7 change log talks about DWARF v2 versus v4 incompatibilities:
1.3-rc7 (20191129)
- released LLVM/Clang 8.0 toolchain built on stable LLVM branch
* UT700/UT699E support with errata work-arounds
* REX support: LEON-REX backend (16-bit ISA) added
* various LEON optimizations included
- Toolchains (GCC and LLVM/Clang) now defaults to DWARF4 debug information,
previously DWARF2 was used. GDB-6.8 used with older tools (GRMON2, TSIM2)
was not capable of always reading the GCC-7 generated DWARF2 codes and had no
support for DWARF4. Enabling DWARF4 makes it possible to perform source level
debugging with GDB-8.2.1 which is supported by the newer tools (GRMON3,
TSIM3).
To use RCC-1.3-rc7 with older tools and GDB-6.8, the binaries should either
1) be stripped, or 2) rebuilt forcing DWARF2 debug format (-gdwarf-2). Build-
scripts for Newlib and RTEMS kernel are available in /src directory.
- Updated RCC to RTEMS kernel to 20191023:
* Updated RTEMS kernel to commit d2efc968e2f644512062de1e06fab20abd2e6854
* Updated Newlib to commit 6661a67747c14cfa7ac91458914037ee296fcd1e
* Updated rtems-tools to commit 12bd8f77bad4779319039fd7be33d006e10f5618
- Fixed samples build issues on GCC
- GRCANFD IP support: extended GRCAN driver with support for new IP and added
new sample in rtems-grcanfd.c.
- Restructured GRCAN and OCCAN drivers to depend on a new common CAN
baud-rate calculator that includes support for CANFD can standard CAN
baud-rate generation.
- RTEMS fix for SMP start-up race condition seen when booting from ROM.
- Support for having custom GPTIMER pre-scaler setting (was fixed to 1MHz)
- Fixed boot issue on LEON3 where GPTIMER initialization depends on previous
GRMON initialization.
- Support for variable GRETH DMA table size (latest GRETH IP required).
- Removed some dependency
- Old GRSPW driver: fix for SET_PACKET_SIZE (driver is depreacted and will
be removed in the future)
- Added precompiled leon3v7 BSP for FPGA designs.
Jens
________________________________
Tesat-Spacecom GmbH & Co. KG
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRA 270977
Persoenlich haftender Gesellschafter: Tesat-Spacecom Geschaeftsfuehrungs GmbH;
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRB 271658;
Geschaeftsfuehrung: Dr. Marc Steckling, Kerstin Basche, Ralf Zimmermann
[Image removed by sender. banner]
CONFIDENTIALITY NOTICE: This email and any attachments are for the sole use of the intended recipient and may contain material that is proprietary, confidential, privileged or otherwise legally protected or restricted under applicable government laws. Any review, disclosure, distributing or other use without expressed permission of the sender is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies without reading, printing, or saving.
URL: <http://lists.rtems.org/pipermail/users/attachments/20200116/46b4b340/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20200116/46b4b340/attachment-0001.jpg>
