Using the EDF scheduler
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Sat Jan 18 00:02:46 UTC 2020
On Fri, Jan 17, 2020 at 4:03 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jan 17, 2020 at 3:00 PM Gedare Bloom <gedare at rtems.org> wrote:
>> From the theory side, this problem is usually addressed using a
>> (sporadic) server. Basically, you create some periodic task at the
>> prioritization that you want (e.g., the shortest relative deadline in
>> the system to usually get the highest priority) and then the server
>> uses its budget to execute the event-based tasks. There are several
>> variations with pros/cons. However, these do not allow for the
>> event-based tasks to be the most responsive in general; with EDF,
>> unless you use relative deadline = 1, there can always be some other
>> task with a shorter absolute deadline. Also, if the server budget gets
>> consumed you have to wait for replenishment. I'm not up-to-date with
>> the latest in SMP schedulers with servers. (Shame on me.)
> I wondered about a band of high rate periodic tasks that check
> for the condition and do it or go to sleep. Binds them to periods
> which introduces latency so that's bad.
> This would work but likely not be acceptable.
A tickless scheduler would allow for a much finer scheduling quantum. At
that point, an ISR could waken a task and hand it a new deadline.
rtems_event_receive_periodic() combined with rtems_event_send_deadline()?
Or perhaps some kind of rate_monotonic_interrupt_server? At least in my
case, the task really is rate-monotonic, but the timing source is both
asynchronous with respect to the kernel tick and much finer.
Jonathan Brandmeyer
URL: <http://lists.rtems.org/pipermail/users/attachments/20200117/b39b7b1c/attachment.html>
