Header missing
Fri Jul 10 14:41:05 UTC 2020
Hi Daniela,
On Fri, Jul 10, 2020 at 7:45 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > Hi Joel,
> > What branch are you on in the rtems source?
> > I’m in the RTEMS_MAKEFILE_PATH
> > The paths of headers:
> > /opt/rtems/5/sparc-rtems5/erc32/lib/include/dev/bspopts.h
> > /opt/rtems/5/sparc-rtems5/erc32/lib/include/bsp.h
This problem isn't reproducing under Linux/cmdline for me (or Joel).
What is your OS, and how did you set up Eclipse?
> >Tks,
> > Daniela.
> Enviado do Email para Windows 10
> De: Joel Sherrill
> Enviado:quinta-feira, 9 de julho de 2020 18:06
> Para: Daniela Oliveira
> Cc:Gedare Bloom; users at rtems.org
> Assunto: Re: Header missing
> On Thu, Jul 9, 2020 at 3:19 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > Hi Gedare,
> > The output of:
> > cd /opt/rtems/5
> > find . -name bspopts.h
> > find : predicate unknown
> > This is the path of header bspopts.h:
> What branch are you on in the rtems source? I just built new tools and RTEMS on the 5 branch and this is what was installed:
> $ find /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/ -name bspopts.h
> /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/lib/include/bspopts.h
> > Tks for help,
> > Daniela.
> De: Gedare Bloom
> Enviado:quinta-feira, 9 de julho de 2020 16:41
> Cc:users at rtems.org
> Hi Daniela,
> On Thu, Jul 9, 2020 at 11:53 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > >Hi guys,
> > > Explaining the steps ..
> > > I had used the RTEMS user manual, so these are the steps:
> > > I built a SPARC tool chain.
> > > - The structure looks like this:
> > > / opt / rtems -> the binaries for compiling, debugging and manipulating files linked with RTEMS / SPARC
> > > / rtems / releases / rsb -> downloaded and unzipped packages for installation
> > > / rtems / kernel -> kernel for BSP generation
> > > / opt / rtems / 5 / sparc-rtems5 / erc32 -> compiled bsp erc32,is the RTEMS_MAKEFILE_PATH
> Can you show the output of:
> cd /opt/rtems/5
> FWIW, I just compiled and installed a clean version of rtems5, and get
> rtems/5$ find . -name bspopts.h
> ./sparc-rtems5/erc32/lib/include/bspopts.h
> > > .../b-erc32-5$ find . -name bspopts.h
> > > ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
> > > Can you identify what tutorial did you follow, and whether you changed
> > > any steps?
> > > I’d used the Rtems User Manual, I’d configurated the project C/C++ in Eclipse, when I receive the fatal error : bspopts.h no such file or directory, then i would changed the bsp.h header
> > > Do you check out the rtems.git/5 branch?
> > > I checked
> > > Is this dev/bspopts.h in your installed tree?
> > > Yeas, confirm.
> > >Tks, Daniela.
> > De: Gedare Bloom
> > Enviado:quinta-feira, 9 de julho de 2020 12:10
> > On Thu, Jul 9, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Mon, Jul 6, 2020 at 3:56 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > Hi guys,
> > > > > I have built a RTEMS 5 sparc, as docs.rtems.org tutorial. When I had built the C/C++ project,
> > > > > I have found a missing header in bsp.h, the bspopts.h. I have no idea why this header appeared inside the DEV directory.
> > > > > I  rewrote the header bsp.h path, <bspopts.h> for <dev/bspopts.h>
> > > > >Then I ask: Is this normal?
> > > No, this is not normal.
> > > any steps?
> > > > > Best regards,
> > > > > Daniela.
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
