How do you plan before starting to code ?
Richi Dubey
richidubey at gmail.com
Sat Jul 11 06:32:14 UTC 2020
Got it, Thank you.
On Fri, Jul 10, 2020 at 8:07 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jul 10, 2020 at 4:58 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Hi,
> > Thanks for the suggestions, they're all very valid and helpful.
> >> We advocate a test-driven development (TDD) approach in RTEMS. Write
> >> the test that should pass once your implementation is correct. Making
> >> it multi-layered from simpler to more complex functionality allows you
> >> to keep track of your progress and make sure you don't break something
> >> (regression) that was working earlier.
> > Should it be a complete test suite like the ones in the folder smptests
> or should it just be an idea in the Doxygen comment?
> For TDD you need to have a real test.
> > On Thu, Jul 9, 2020 at 8:27 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Richi,
> >> Some good advice from others. I'll just add a few more notes.
> >> On Thu, Jul 9, 2020 at 2:23 AM Richi Dubey <richidubey at gmail.com>
> wrote:
> >> > Hi,
> >> > I understand. I'll learn how to use Doxygen and put it in my codes.
> Thank you.
> >> Not just that, he also suggests you can start with a doxygen
> >> description before you really start coding. This is useful to help
> >> think through the interfaces and structures of your functions before
> >> you start to implement them.
> >> If you need help to run doxygen locally, ask.
> >> > On Thu, Jul 9, 2020 at 12:43 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> >> Hello Richi,
> >> >> we use Doxygen to document the software design. Maybe you can write
> your
> >> >> high-level description with it. This way it is integrated already
> >> >> integrated in the sources. You can use @dot for graphs and @msc for
> >> >> message sequences.
> >> Personally, I like to start with pen and paper drafts in a notebook. I
> >> keep my notebook handy to keep track of revisions and ideas. I'll move
> >> to either text- or graphic-based design if I need to share it with
> >> others. Text-based is easier to integrate in documentation, while
> >> graphic-based can make for some really nice explanations in blogs and
> >> other reports. Doing text-based in doxygen is a good way to save time
> >> on internal doco later.
> >> >> I would document the data structures and the invariants of the data
> >> >> structures. I would also try to write code which checks that the
> >> >> invariants are satisfied. This can be used in _Assert() and
> RTEMS_DEBUG
> >> >> blocks.
> >> >> I would also write test cases. You can already run the test cases
> with:
> https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#arbitrary-processor-affinity-priority-smp-scheduler
> >> >> There should be test cases which would fail with the Linux push and
> pull
> >> >> scheduler.
> >> >> You should identify the key scheduler operations (e.g. block and
> >> >> unblock) and write a high level description of the algorithms used
> for
> >> >> these operations in some sort of pseudo code.
> >> >> Sebastian Huber, embedded brains GmbH
> >> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> >> Phone : +49 89 189 47 41-16
> >> >> Fax : +49 89 189 47 41-09
> >> >> E-Mail : sebastian.huber at embedded-brains.de
> >> >> PGP : Public key available on request.
> >> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >> > _______________________________________________
> >> > users mailing list
> >> > users at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20200711/eea5f145/attachment.html>
