Header missing
Gedare Bloom
gedare at rtems.org
Thu Jul 16 05:25:50 UTC 2020
On Wed, Jul 15, 2020 at 2:15 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > Hi guys,
> > I have installed with this steps exactly but the bsp_specs was not inside the include directory, he's in lib directory.
that's normal
> >This is the path of bsp_specs:
it should be at ./sparc-rtems5/erc32/lib/bsp_specs
within your install point (prefix)
> > No root at localhost:~
> > yum install autoconf automake binutils gcc gcc-c++ gdb make patch pax \ bison flex xz unzip ncurses-devel texinfo zlib-devel python-devel git
> > mkdir comav/rtems/releases
> > wget https://ftp.rtems.org/pub/rtems/releases/5/rc/5.1.0-rc1/sources/rtems-source-builder-5.1.0-rc1.tar.xz
> > tar Jxf rtems-source-builder-5.1.0-rc1.tar.xz
> > cd rtems-source-builder-5.1.0-rc1/
> > ../source-builder/sb-set-builder –prefix=/opt/rtems/5 5/rtems-sparc
> > cd
> > cd comav/rtems/kernel
> > wget https://ftp.rtems.org/pub/rtems/releases/5/rc/5.1.0-rc1/sources/rtems-5.1.0-rc1.tar.xz
> > tar Jxf rtems-5.1.0-rc1.tar.xz
> > export PATH=/opt/rtems/5/bin:$PATH
> > mv /rtems/releases/rtems-source-builder-5.1.0-rc1 /rtems/releases/rsb
> > cd rtems
> > ./bootstrap -c && $HOME/comav/rtems/rsb/source-builder/sb-bootstrap
> > cd comav/rtems/kernel/erc32
> > $HOME/comav/rtems/kernel/rtems/configure --prefix=/opt/rtems/5 --target=sparc-rtems5 --enable-rtemsbsp=erc32 -- disable-posix --disable-networking
double check the space in "-- disable-posix" and, also, try with
enable-posix to see if you get anything different.
> > make all install
> > export RTEMS_MAKEFILE_PATH=/opt/rtems/5/sparc-rtems5/erc32
> > > There is something that put the docs in other directory that is not path include correctly.
I'm not sure what you mean by this last, but the docs build is now
separate from the rtems kernel build.
> > Tks for help
> > Daniela.
> Enviado do Email para Windows 10
> De: Daniela Oliveira
> Enviado:sexta-feira, 10 de julho de 2020 17:42
> Para: joel at rtems.org
> Cc:users at rtems.org
> Assunto: RES: Header missing
> > Sorry guys,
> >This is the exact command then I ‘ve used:
> > $ wget https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2006-1/sources/rtems-source-builder-5.0.0-m2006-1.tar.xz
> > I´d intalled git in others VMWares. But i’ll reduild the installation and notice here.
> >Tks for help.
> De: Joel Sherrill
> Enviado:sexta-feira, 10 de julho de 2020 12:37
> Para: Daniela Oliveira
> Cc:Gedare Bloom; users at rtems.org
> Assunto: Re: Header missing
> On Fri, Jul 10, 2020 at 10:20 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> >Do you have the exact command or download by chance?
> > $ git clone git://git.rtems.org/rtems rtems
> > Maybe this.
> > Anything else may not be building the right repositor.
> I'm confused. You fetched the RSB from a release candidate snapshot and then cloned the repo.
> I don't know what is going on but you need a consistent set: all git or all m2006-1.
> Gedare and I built from git and switched to the 5 branch for the RSB and RTEMS.
> After building with the RSB, put the ${PREFIX}/bin at the front of your PATH and bootstrap the RTEMS source (if from git). Then build and install the BSP into a clean place (as Gedare suggested).
> There shouldn't be anything different at the moment between m2006-1 and the 5 branch on git but that's a combination we would never recommend or test.
> >Tks for help.
> De: Gedare Bloom
> Enviado:sexta-feira, 10 de julho de 2020 12:08
> Cc:joel at rtems.org; users at rtems.org
> On Fri, Jul 10, 2020 at 9:01 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > Hi guys,
> > > What is your OS, and how did you set up Eclipse?
> > > I’m using the Linux CentOS 7, in VMWare 15.5 .
> Thanks that is helpful.
> > > Eclipse:
> > > Cross Settings:
> > > Prefix: sparc-rtems5-
> > > Path: /opt/rtems/5/bin
> > > Includes: “${RTEMS_MAKEFILE_PATH}/lib/include”
> > > Also, are you using the RTEMS-5 release download? Can you send where you got it from?
> > > Yeah, I’ve downloaded from git.rtems.org/rtems
> The RTEMS-5 release is at
> It contains a self-describing readme.
> The git.rtems.org/rtems.git has a branch for rtems 5 that would need
> to be checked out in order to build properly, then you would use the
> directions of the quick start, e.g.,:
> git clone git://git.rtems.org/rtems.git
> cd rtems
> git checkout -t origin/5
> ./rtems-bootstrap
> etc.
> Anything else may not be building the right repository.
> > > Daniela.
> > De: Gedare Bloom
> > Enviado:sexta-feira, 10 de julho de 2020 11:42
> > On Fri, Jul 10, 2020 at 8:41 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > Hi Daniela,
> > > On Fri, Jul 10, 2020 at 7:45 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > Hi Joel,
> > > > > What branch are you on in the rtems source?
> > > > > I’m in the RTEMS_MAKEFILE_PATH
> > > > > The paths of headers:
> > > > > /opt/rtems/5/sparc-rtems5/erc32/lib/include/dev/bspopts.h
> > > > > /opt/rtems/5/sparc-rtems5/erc32/lib/include/bsp.h
> > > This problem isn't reproducing under Linux/cmdline for me (or Joel).
> > you got it from? I want to verify.
> > > > >Tks,
> > > > > Daniela.
> > > > De: Joel Sherrill
> > > > Enviado:quinta-feira, 9 de julho de 2020 18:06
> > > > On Thu, Jul 9, 2020 at 3:19 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > Hi Gedare,
> > > > > The output of:
> > > > > cd /opt/rtems/5
> > > > > find . -name bspopts.h
> > > > > find : predicate unknown
> > > > > This is the path of header bspopts.h:
> > > > What branch are you on in the rtems source? I just built new tools and RTEMS on the 5 branch and this is what was installed:
> > > > $ find /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/ -name bspopts.h
> > > > /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/lib/include/bspopts.h
> > > > > Tks for help,
> > > > > Daniela.
> > > > De: Gedare Bloom
> > > > Enviado:quinta-feira, 9 de julho de 2020 16:41
> > > > Hi Daniela,
> > > > On Thu, Jul 9, 2020 at 11:53 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > >Hi guys,
> > > > > > Explaining the steps ..
> > > > > > I had used the RTEMS user manual, so these are the steps:
> > > > > > I built a SPARC tool chain.
> > > > > > - The structure looks like this:
> > > > > > / opt / rtems -> the binaries for compiling, debugging and manipulating files linked with RTEMS / SPARC
> > > > > > / rtems / releases / rsb -> downloaded and unzipped packages for installation
> > > > > > / rtems / kernel -> kernel for BSP generation
> > > > > > / opt / rtems / 5 / sparc-rtems5 / erc32 -> compiled bsp erc32,is the RTEMS_MAKEFILE_PATH
> > > > Can you show the output of:
> > > > cd /opt/rtems/5
> > > > FWIW, I just compiled and installed a clean version of rtems5, and get
> > > > rtems/5$ find . -name bspopts.h
> > > > ./sparc-rtems5/erc32/lib/include/bspopts.h
> > > > > > .../b-erc32-5$ find . -name bspopts.h
> > > > > > ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
> > > > > > Can you identify what tutorial did you follow, and whether you changed
> > > > > > any steps?
> > > > > > I’d used the Rtems User Manual, I’d configurated the project C/C++ in Eclipse, when I receive the fatal error : bspopts.h no such file or directory, then i would changed the bsp.h header
> > > > > > Do you check out the rtems.git/5 branch?
> > > > > > I checked
> > > > > > Is this dev/bspopts.h in your installed tree?
> > > > > > Yeas, confirm.
> > > > > >Tks, Daniela.
> > > > > De: Gedare Bloom
> > > > > Enviado:quinta-feira, 9 de julho de 2020 12:10
> > > > > On Thu, Jul 9, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > > > > On Mon, Jul 6, 2020 at 3:56 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > > > > Hi guys,
> > > > > > > > I have built a RTEMS 5 sparc, as docs.rtems.org tutorial. When I had built the C/C++ project,
> > > > > > > > I have found a missing header in bsp.h, the bspopts.h. I have no idea why this header appeared inside the DEV directory.
> > > > > > > > I rewrote the header bsp.h path, <bspopts.h> for <dev/bspopts.h>
> > > > > > > >Then I ask: Is this normal?
> > > > > > No, this is not normal.
> > > > > > any steps?
> > > > > > > > Best regards,
> > > > > > > > Daniela.
> > > > > > > _______________________________________________
> > > > > > > users mailing list
> > > > > > > users at rtems.org
> > > > > > > http://lists.rtems.org/mailman/listinfo/users
> > > > users mailing list
> > > > users at rtems.org
> users mailing list
> users at rtems.org
