Header missing
Fri Jul 17 15:57:02 UTC 2020
On Fri, Jul 17, 2020 at 9:31 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> >Hi guys,
> > There is a problem in RTEMS_MAKEFILE_PATH, I think him was not built correctly or the path changed.
> > But I affirm that I have executed this steps exactly how  your suggested
OK. I don't normally test the application build after an install. I
don't have a good setup for that at the moment. Hopefully someone else
might chime in.
You might check if there have been any changes made in the
rtems-examples.git repository for directions on application builds.
> >Tks
> Enviado do Email para Windows 10
> De: Gedare Bloom
> Enviado:quinta-feira, 16 de julho de 2020 02:26
> Para: Daniela Oliveira
> Cc:joel at rtems.org; users at rtems.org
> Assunto: Re: Header missing
> On Wed, Jul 15, 2020 at 2:15 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > Hi guys,
> > > I have installed with this steps exactly but the bsp_specs was not inside the include directory, he's in lib directory.
> that's normal
> > >This is the path of bsp_specs:
> it should be at ./sparc-rtems5/erc32/lib/bsp_specs
> within your install point (prefix)
> > > No root at localhost:~
> > > yum install autoconf automake binutils gcc gcc-c++ gdb make patch pax \ bison flex xz unzip ncurses-devel texinfo zlib-devel python-devel git
> > > mkdir comav/rtems/releases
> > > wget https://ftp.rtems.org/pub/rtems/releases/5/rc/5.1.0-rc1/sources/rtems-source-builder-5.1.0-rc1.tar.xz
> > > tar Jxf rtems-source-builder-5.1.0-rc1.tar.xz
> > > cd rtems-source-builder-5.1.0-rc1/
> > > ../source-builder/sb-set-builder –prefix=/opt/rtems/5 5/rtems-sparc
> > > cd
> > > cd comav/rtems/kernel
> > > wget https://ftp.rtems.org/pub/rtems/releases/5/rc/5.1.0-rc1/sources/rtems-5.1.0-rc1.tar.xz
> > > tar Jxf rtems-5.1.0-rc1.tar.xz
> > > export PATH=/opt/rtems/5/bin:$PATH
> > > mv /rtems/releases/rtems-source-builder-5.1.0-rc1 /rtems/releases/rsb
> > > cd rtems
> > > ./bootstrap -c && $HOME/comav/rtems/rsb/source-builder/sb-bootstrap
> > > cd comav/rtems/kernel/erc32
> > > $HOME/comav/rtems/kernel/rtems/configure --prefix=/opt/rtems/5 --target=sparc-rtems5 --enable-rtemsbsp=erc32 -- disable-posix  --disable-networking
> double check the space in "-- disable-posix" and, also, try with
> enable-posix to see if you get anything different.
> > > make all install
> > > export RTEMS_MAKEFILE_PATH=/opt/rtems/5/sparc-rtems5/erc32
> > > > There is something that put the docs in other directory that is not  path include correctly.
> I'm not sure what you mean by this last, but the docs build is now
> separate from the rtems kernel build.
> > > Tks for help
> > > Daniela.
> > De: Daniela Oliveira
> > Enviado:sexta-feira, 10 de julho de 2020 17:42
> > Para: joel at rtems.org
> > Cc:users at rtems.org
> > Assunto: RES: Header missing
> > > Sorry guys,
> > >This is the exact command then I ‘ve used:
> > > $ wget https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2006-1/sources/rtems-source-builder-5.0.0-m2006-1.tar.xz
> > > I´d intalled git in others VMWares. But i’ll reduild the installation and notice here.
> > >Tks for help.
> > De: Joel Sherrill
> > Enviado:sexta-feira, 10 de julho de 2020 12:37
> > Cc:Gedare Bloom; users at rtems.org
> > On Fri, Jul 10, 2020 at 10:20 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > >Do you have the exact command or download by chance?
> > > $ git clone git://git.rtems.org/rtems rtems
> > > Maybe this.
> > > Anything else may not be building the right repositor.
> > I'm confused. You fetched the RSB from a release candidate snapshot and then cloned the repo.
> > I don't know what is going on but you need a consistent set: all git or all m2006-1.
> > Gedare and I built from git and switched to the 5 branch for the RSB and RTEMS.
> > After building with the RSB, put the ${PREFIX}/bin at the front of your PATH and bootstrap the RTEMS source (if from git).  Then build and install the BSP into a clean place (as Gedare suggested).
> > There shouldn't be anything different at the moment between m2006-1 and the 5 branch on git but that's a combination we would never recommend or test.
> > >Tks for help.
> > De: Gedare Bloom
> > Enviado:sexta-feira, 10 de julho de 2020 12:08
> > On Fri, Jul 10, 2020 at 9:01 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > Hi guys,
> > > > What is your OS, and how did you set up Eclipse?
> > > > I’m using the Linux CentOS 7, in VMWare 15.5 .
> > Thanks that is helpful.
> > > > Eclipse:
> > > > Cross Settings:
> > > > Prefix: sparc-rtems5-
> > > > Path: /opt/rtems/5/bin
> > > > Includes: “${RTEMS_MAKEFILE_PATH}/lib/include”
> > > > Also, are you using the RTEMS-5 release download? Can you send where you got it from?
> > > > Yeah, I’ve downloaded from git.rtems.org/rtems
> > The RTEMS-5 release is at
> > It contains a self-describing readme.
> > The git.rtems.org/rtems.git has a branch for rtems 5 that would need
> > to be checked out in order to build properly, then you would use the
> > directions of the quick start, e.g.,:
> > git clone git://git.rtems.org/rtems.git
> > cd rtems
> > git checkout -t origin/5
> > ./rtems-bootstrap
> > etc.
> > Anything else may not be building the right repository.
> > > > Daniela.
> > > De: Gedare Bloom
> > > Enviado:sexta-feira, 10 de julho de 2020 11:42
> > > On Fri, Jul 10, 2020 at 8:41 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > > Hi Daniela,
> > > > On Fri, Jul 10, 2020 at 7:45 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > > Hi Joel,
> > > > > > What branch are you on in the rtems source?
> > > > > > I’m in the RTEMS_MAKEFILE_PATH
> > > > > > The paths of headers:
> > > > > > /opt/rtems/5/sparc-rtems5/erc32/lib/include/dev/bspopts.h
> > > > > > /opt/rtems/5/sparc-rtems5/erc32/lib/include/bsp.h
> > > > This problem isn't reproducing under Linux/cmdline for me (or Joel).
> > > you got it from? I want to verify.
> > > > > >Tks,
> > > > > > Daniela.
> > > > > De: Joel Sherrill
> > > > > Enviado:quinta-feira, 9 de julho de 2020 18:06
> > > > > On Thu, Jul 9, 2020 at 3:19 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > > Hi Gedare,
> > > > > > The output of:
> > > > > > cd /opt/rtems/5
> > > > > > find . -name bspopts.h
> > > > > > find : predicate unknown
> > > > > > This is the path of header bspopts.h:
> > > > > What branch are you on in the rtems source? I just built new tools and RTEMS on the 5 branch and this is what was installed:
> > > > > $ find /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/ -name bspopts.h
> > > > > /home/joel/rtems-work/tools/5/bsp-install/sparc-rtems5/erc32/lib/include/bspopts.h
> > > > > > Tks for help,
> > > > > > Daniela.
> > > > > De: Gedare Bloom
> > > > > Enviado:quinta-feira, 9 de julho de 2020 16:41
> > > > > Hi Daniela,
> > > > > On Thu, Jul 9, 2020 at 11:53 AM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > > >Hi guys,
> > > > > > > Explaining the steps ..
> > > > > > > I had used the RTEMS user manual, so these are the steps:
> > > > > > > I built a SPARC tool chain.
> > > > > > > - The structure looks like this:
> > > > > > > / opt / rtems -> the binaries for compiling, debugging and manipulating files linked with RTEMS / SPARC
> > > > > > > / rtems / releases / rsb -> downloaded and unzipped packages for installation
> > > > > > > / rtems / kernel -> kernel for BSP generation
> > > > > > > / opt / rtems / 5 / sparc-rtems5 / erc32 -> compiled bsp erc32,is the RTEMS_MAKEFILE_PATH
> > > > > Can you show the output of:
> > > > > cd /opt/rtems/5
> > > > > FWIW, I just compiled and installed a clean version of rtems5, and get
> > > > > rtems/5$ find . -name bspopts.h
> > > > > ./sparc-rtems5/erc32/lib/include/bspopts.h
> > > > > > > .../b-erc32-5$ find . -name bspopts.h
> > > > > > > ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
> > > > > > > Can you identify what tutorial did you follow, and whether you changed
> > > > > > > any steps?
> > > > > > > I’d used the Rtems User Manual, I’d configurated the project C/C++ in Eclipse, when I receive the fatal error : bspopts.h no such file or directory, then i would changed the bsp.h header
> > > > > > > Do you check out the rtems.git/5 branch?
> > > > > > > I checked
> > > > > > > Is this dev/bspopts.h in your installed tree?
> > > > > > > Yeas, confirm.
> > > > > > >Tks, Daniela.
> > > > > > De: Gedare Bloom
> > > > > > Enviado:quinta-feira, 9 de julho de 2020 12:10
> > > > > > On Thu, Jul 9, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > > > > > On Mon, Jul 6, 2020 at 3:56 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > > > > > > > Hi guys,
> > > > > > > > > I have built a RTEMS 5 sparc, as docs.rtems.org tutorial. When I had built the C/C++ project,
> > > > > > > > > I have found a missing header in bsp.h, the bspopts.h. I have no idea why this header appeared inside the DEV directory.
> > > > > > > > > I  rewrote the header bsp.h path, <bspopts.h> for <dev/bspopts.h>
> > > > > > > > >Then I ask: Is this normal?
> > > > > > > No, this is not normal.
> > > > > > > any steps?
> > > > > > > > > Best regards,
> > > > > > > > > Daniela.
> > > > > > > > _______________________________________________
> > > > > > > > users mailing list
> > > > > > > > users at rtems.org
> > > > > > > > http://lists.rtems.org/mailman/listinfo/users
> > > > > users mailing list
> > > > > users at rtems.org
> > users mailing list
> > users at rtems.org
