Guarantee rtems_timer_server_fire_after() will be 'after' interval
Gedare Bloom
gedare at rtems.org
Sat Jul 25 16:20:43 UTC 2020
Can you reproduce this with the RTEMS 5 release?
Is it a public BSP, or can it reproduce on a public BSP?
On Fri, Jun 5, 2020 at 1:29 AM Matthew J Fletcher <amimjf at gmail.com> wrote:
> Replying to myself.
> Fetch is from RTEMS commit d2efc968e2f644512062de1e06fab20abd2e6854 (around 2019-10-25)
> On Fri, 5 Jun 2020 at 08:24, Matthew J Fletcher <amimjf at gmail.com> wrote:
>> RTEMS version: 5.0.0
>> RTEMS tools: 7.4.1 20190514 [gcc-7-branch revision e394c07a6f0:5dcbdf0fab0:9fe5ced54b87698db3c13994155020ed003cbc7f]
>> Its not a big problem for the application, we can always check for multiple invocations in the same second.
>> I cant quite believe its a core RTEMS issue, would seem BSP specific.
>> On Thu, 4 Jun 2020 at 23:42, Joel Sherrill <joel at rtems.org> wrote:
>>> What version Matthew?
>>> On Thu, Jun 4, 2020 at 4:24 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> Yes, it should. If not, have to chase down a bug somewhere.
>>>> https://docs.rtems.org/branches/master/c-user/timer_manager.html#rtems-timer-server-fire-after
>>>> On Wed, Jun 3, 2020 at 2:05 AM Matthew J Fletcher <amimjf at gmail.com> wrote:
>>>> > Hi,
>>>> > Does the implementation of rtems_timer_server_fire_after() ensure that the supplied routine will be called 'after' the interval ?
>>>> > On my ARMv7M BSP with a 10ms tick and 100 passed as the interval argument i occasionally (once in 10,00 or so) see the following;
>>>> > routine called - 0 millis
>>>> > routine called - 980 millis
>>>> > I am using rtems_clock_get_ticks_since_boot() to get the millis
>>>> > regards
>>>> > Matthew J Fletcher
>>>> > _______________________________________________
>>>> > users mailing list
>>>> > users at rtems.org
>>>> > http://lists.rtems.org/mailman/listinfo/users
>>>> users mailing list
>>>> users at rtems.org
>> regards
>> Matthew J Fletcher
> regards
> Matthew J Fletcher
> users mailing list
> users at rtems.org
