Guarantee rtems_timer_server_fire_after() will be 'after' interval
Thu Jun 4 21:24:37 UTC 2020
Yes, it should. If not, have to chase down a bug somewhere.
https://docs.rtems.org/branches/master/c-user/timer_manager.html#rtems-timer-server-fire-after
On Wed, Jun 3, 2020 at 2:05 AM Matthew J Fletcher <amimjf at gmail.com> wrote:
> Hi,
> Does the implementation of rtems_timer_server_fire_after() ensure that the supplied routine will be called 'after' the interval ?
> On my ARMv7M BSP with a 10ms tick and 100 passed as the interval argument i occasionally (once in 10,00 or so) see the following;
> routine called - 0 millis
> routine called - 980 millis
> I am using rtems_clock_get_ticks_since_boot() to get the millis
> regards
> Matthew J Fletcher
> users mailing list
> users at rtems.org
