Guarantee rtems_timer_server_fire_after() will be 'after' interval
Matthew J Fletcher
amimjf at gmail.com
Fri Jun 5 07:24:24 UTC 2020
RTEMS version: 5.0.0
RTEMS tools: 7.4.1 20190514 [gcc-7-branch revision
e394c07a6f0:5dcbdf0fab0:9fe5ced54b87698db3c13994155020ed003cbc7f]
Its not a big problem for the application, we can always check for multiple
invocations in the same second.
I cant quite believe its a core RTEMS issue, would seem BSP specific.
On Thu, 4 Jun 2020 at 23:42, Joel Sherrill <joel at rtems.org> wrote:
> What version Matthew?
> On Thu, Jun 4, 2020 at 4:24 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Yes, it should. If not, have to chase down a bug somewhere.
>> https://docs.rtems.org/branches/master/c-user/timer_manager.html#rtems-timer-server-fire-after
>> On Wed, Jun 3, 2020 at 2:05 AM Matthew J Fletcher <amimjf at gmail.com>
>> wrote:
>> > Hi,
>> > Does the implementation of rtems_timer_server_fire_after() ensure that
>> the supplied routine will be called 'after' the interval ?
>> > On my ARMv7M BSP with a 10ms tick and 100 passed as the interval
>> argument i occasionally (once in 10,00 or so) see the following;
>> > routine called - 0 millis
>> > routine called - 980 millis
>> > I am using rtems_clock_get_ticks_since_boot() to get the millis
>> > regards
>> > Matthew J Fletcher
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20200605/79e48429/attachment.html>
