RTEMS Release Snapshot: 5.0.0-m2002 (06 Feb 2020)
Chris Johns
chrisj at rtems.org
Tue Mar 3 02:15:52 UTC 2020
On 20/2/20 5:46 am, Michael Davidsaver wrote:
> On 2/12/20 7:58 PM, Chris Johns wrote:
>> It should have worked. I have built the 5/bsps/beagleboneblack build set and it
>> worked up building libbsd where I have a packaging issue to sort out, so I am
>> interested in why you are seeing an error.
> Taking this as a starting point, I create config/5/bsps/pc686.bset with
>> cat config/5/bsps/pc686.bset
>> %define mail_single_report 1
>> %define with_rtems_bsp pc686
>> %define rtems_target i386-rtems5
>> %define rtems_host %{rtems_target}
>> 5/rtems-i386
>> 5/rtems-kernel
>> 5/rtems-libbsd
>> 5/rtems-packages
> I then try:
>> ../source-builder/sb-set-builder --prefix /home/mdavidsaver/source/rtems/usr 5/bsps/pc686 --source-only-download
> which errors when trying to download the rtems kernel source.
>> config: tools/rtems-kernel-5.cfg
>> package: i386-rtems5-kernel-pc686-1
>> download: https://git.rtems.org/rtems/snapshot/rtems-5.0.0-m2002.tar.bz2 -> sources/rtems-5.0.0-m2002.tar.xz
>> download: https://git.rtems.org/rtems/snapshot/rtems-5.0.0-m2002.tar.bz2: error: HTTP Error 404: Not found
>> error: downloading https://git.rtems.org/rtems/snapshot/rtems-5.0.0-m2002.tar.bz2: all paths have failed, giving up
>> Build FAILED
> If I manually download rtems-5.0.0-m2002.tar.xz then it gets further, but fails on:
>> config: tools/rtems-libbsd-5.cfg
>> package: rtems-libbsd-vafaeccc05a556f6aa25ba044a7e49d6aa634a59e-x86_64-linux-gnu-1
>> download: https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-5.0.0-m2002.tar.xz -> sources/rtems-libbsd-5.0.0-m2002.tar.xz
>> download: https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-5.0.0-m2002.tar.xz: error: HTTP Error 400: Bad request
>> error: downloading https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-5.0.0-m2002.tar.xz: all paths have failed, giving up
>> Build FAILED
I think this has been addressed in the release scripts. Then there was ..
https://git.rtems.org/rtems-source-builder/commit/?id=3dd974990e11d12123902349e0f0bc8eba35e8e8
> I can't see how to fetch this manually, so I removed '5/rtems-libbsd' for the moment.
> Proceeding with a build ultimately fails on curl with missing gethostbyname(),
> which I guess is to be expected as I've omitted libbsd.
I think this has been fixed. The kernel version is current as well as libbsd
which has now switched to the 5-freebsd12 branch.
The ticket #3893 has addressed a number of issues when building 3rd party packages.
I am looking to create a m2003 snapshot to capture all this.
>> Could you please create a ticket with the error log and I will take a look?
> Is this strictly necessary? I'd rather conduct this discussion on list.
No not at all, just means I am less likely to forget something so it helps me.
