"Option 'subdir-objects' is disabled"
Michael Westfall
mwestfal at gemini.edu
Fri Mar 20 00:56:53 UTC 2020
Oh, never mind.
I forgot to update $PATH with the location of the crosscompiler tools.
On Thu, Mar 19, 2020 at 9:49 PM Michael Westfall <mwestfal at gemini.edu>
wrote:
> I need a tip.
> Seems to be related to automake (I have ver. 1.15.1)
> With a fresh download of rtems-4.10, the boostrap step fails:
> mikew at pollux:/gem_sw/targetOS/RTEMS/source/rtems-4.10$ ./bootstrap
> ./contrib/rtemsrpms
> configure.ac:11: installing './config.guess'
> configure.ac:11: installing './config.sub'
> configure.ac:15: installing './install-sh'
> configure.ac:15: installing './missing'
> ./testsuites/itrontests
> configure.ac:10: installing '../../config.guess'
> configure.ac:10: installing '../../config.sub'
> configure.ac:12: installing '../../install-sh'
> configure.ac:12: installing '../../missing'
> ./testsuites/mptests
> mp01/node1/Makefile.am:8: warning: source file '../init.c' is in a
> subdirectory,
> mp01/node1/Makefile.am:8: but option 'subdir-objects' is disabled
> automake: warning: possible forward-incompatibility.
> automake: At least a source file is in a subdirectory, but the
> 'subdir-objects'
> automake: automake option hasn't been enabled. For now, the corresponding
> output
> automake: object file(s) will be placed in the top-level directory.
> However,
> automake: this behaviour will change in future Automake versions: they will
> automake: unconditionally cause object files to be placed in the same
> subdirectory
> automake: of the corresponding sources.
> automake: You are advised to start using 'subdir-objects' option
> throughout your
> automake: project, to avoid future incompatibilities.
> mp01/node1/Makefile.am:8: warning: source file '../task1.c' is in a
> subdirectory,
> mp01/node2/Makefile.am:8: warning: source file '../init.c' is in a
> subdirectory,
> mp01/node2/Makefile.am:8: but option 'subdir-objects' is disabled
> mp01/node2/Makefile.am:8: warning: source file '../task1.c' is in a
> subdirectory,
> mp02/node1/Makefile.am:8: warning: source file '../init.c' is in a
> subdirectory,
> mp02/node1/Makefile.am:8: but option 'subdir-objects' is disabled
> mp02/node1/Makefile.am:8: warning: source file '../task1.c' is in a
> subdirectory,
> mp02/node2/Makefile.am:8: warning: source file '../init.c' is in a
> subdirectory,
> mp02/node2/Makefile.am:8: but option 'subdir-objects' is disabled
> mp02/node2/Makefile.am:8: warning: source file '../task1.c' is in a
> subdirectory,
> and so on and so forth...
> Mike Westfall
> Control Systems Software Engineer
Mike Westfall
URL: <http://lists.rtems.org/pipermail/users/attachments/20200319/80b67ffe/attachment.html>
