source-builder randomly hangs
Anders Montonen
Anders.Montonen at iki.fi
Tue May 5 07:26:19 UTC 2020
Hi,
> On 4 May 2020, at 4:05, Chris Johns <chrisj at rtems.org> wrote:
> On 2/5/20 10:04 pm, Anders Montonen wrote:
>> A couple of times I’ve had source-builder hang seemingly randomly, with the following Python backtrace:
> Do you see this problem with the bootstrap script 'rtems-bootstrap' in the top of the rtems.git rep?
I haven’t seen it yet, but I haven’t run it very many times.
> Interesting and your analysis sounds right. I am not sure how this could be handled. A test case with execute.py would be a good start, see the end of the file.
We could try passing “universal_newlines=True” to the subprocess.Popen() constructor. This will open stdin/stdout/stderr in text mode, using the current locale setting. Python 3.6+ allows specifying the encoding in the constructor, if that makes a difference. Another option would be to manually wrap the output streams in an io.TextIOWrapper, which is essentially what Popen() does when given any of these arguments.
Regards,
Anders
