Help RTEMS 5
Vijay Kumar Banerjee
vijay at rtems.org
Tue May 12 14:14:27 UTC 2020
Hi Daniela
On Tue, May 12, 2020 at 7:24 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> >Hi,
> > I'm installing rtems 5 and came across the following error: checking for sparc-rtems 5-strip ... no
There is a space in "sparc-rtems 5-strip" if this is not a typo that
seeped in while pasting here, then
this might be the source of the error. If that's not the case then
please check that you have
sparc-rtems5-strip in your PATH.
> > when I create the makefile.
> > I saw some reports of this same error and I couldn't find the solution.
Did the sparc-rtems5 toolchain build complete successfully?
> > I would appreciate a help, as this is the first time I install rtems.
> >Tks
> >Daniela
> Enviado do Email para Windows 10
> users mailing list
> users at rtems.org
