Error Rtems 5
Jan.Sommer at dlr.de
Fri May 22 11:34:53 UTC 2020
> Hi Jan,
>> Do you have the cross-compiler generated with rtems-source-builder in your PATH?
> Yes
> I’m installing the RTEMS 5 with the Quick start on
> https://docs.rtems.org/branches/master/user/installation/kernel.html
> Then the step 5.3.4 Building a BSP with configure command but the sparc-rtems5-strip isn’t check
Again, can you please attach a full log of the output of your configure step?
Is there a sparc-rtems5-strip binary in your PATH? You can check by running "which sparc-rtems5-strip".
> then this generate a warning : using cross tools not prefixed with host triplet
Ok, but this is just a warning, not an error.
What happens if you run "make" does the compilation fail?
Best regards,
Jan
> Best regards,
> Daniela
> Enviado do Email para Windows 10
> De: Jan.Sommer at dlr.de
> Enviado:terça-feira, 19 de maio de 2020 03:18
> Para: oliveiradad at gmail.com
> Assunto: RE: RE: Error Rtems 5
> Hi Daniela,
> What is the output of “which sparc-rtems5-gcc”?
> Does the configure step actually return with an error message?
> Please post the full log of your configure step as text.
> It is difficult to come to any conclusions with only limited information.
> Best regards,
> Jan
> From: Daniela Oliveira [mailto:oliveiradad at gmail.com]
> Sent: Monday, May 18, 2020 3:59 PM
> To: Sommer, Jan; users at rtems.org
> Subject: RES: RE: Error Rtems 5
>>Hi Jan,
>> This is a part of the tutorial I'm following, notice the checking strip and the second image the error I'm reporting...
>>Tks
>>Daniela
> Enviado:segunda-feira, 18 de maio de 2020 10:39
> Para: oliveiradad at gmail.com; users at rtems.org
> Assunto: RE: Error Rtems 5
> Hi Daniela,
> Can you elaborate a bit where the error is?
> I can’t see an error message in your screenshot.
> I would also recommend to copy your relevant output as text into the email instead of an image.
> That makes it easier to read and comment on certain lines.
> Best regards,
> Jan
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Daniela Oliveira
> Sent: Monday, May 18, 2020 3:28 PM
> To: users at rtems.org
> Subject: Error Rtems 5
> >Hi,
> > I'm installing rtems 5 and came across the following error when I create the makefile.
> > I saw some reports of this same error and I couldn't find the solution.
> >I appreciate a help to this...
> >Tks
> >Daniela
