Can't create .exe samples
Richi Dubey
richidubey at gmail.com
Fri May 29 14:41:14 UTC 2020
Hii Borja,
You are not supposed to compile the examples(testsuites) from the src/rtems
folder.
Goto the examples in your build folder, which for you would(mostly) be :
/home/tfg/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites and you
can run the command make there!
Also make sure you have set your PATH variable by running : export
PATH=$HOME/tfg/quick-start/rtems/5/bin:"$PATH"
Let us know if it works after finishing these steps.
Good luck!
On Fri, May 29, 2020 at 3:56 PM BORJA HERRADOR MARTIN <
100329957 at alumnos.uc3m.es> wrote:
> Hello, good morning.
> I have been trying to run the examples, using sparc-leon3 architecture I
> can run examples with WAF.
> The problem is when I install the i386-pc386 architecture and I want to
> run the examples with qemu. In the examples folder I don't have a Makefile
> and I don't know how to compile the examples to get the .exe for the
> i386-pc386 architecture.
> [image: Carpeta samples.png]
> Can you tell me please how to compile the examples?
> Greetings.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200529/5f422f7b/attachment-0001.html>
Name: Carpeta samples.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20200529/5f422f7b/attachment-0001.png>
