rtems-tftp server not working with iPXE.
Karel Gardas karel.gardas at centrum.cz
Mon Sep 7 06:06:48 UTC 2020
On 9/7/20 2:34 AM, Chris Johns wrote:
> On 7/9/20 8:29 am, Chris Johns wrote:
>> Hmm looks like the socket returns a string in Python 2 and bytes in Python 3. I
>> will need to play around to find a suitable solution for this.
> Fixed on master. Please test and let me know how you go.
Thanks, but no go here on Ubuntu 18.04 LTS. Perhaps I don't know usage
well, but I:
- dhcp
- boot tftp://<host>/smp01.exe
on iPXE hardware side.
But tftp server throws FileNotFoundError on me as if the file smp01.exe
was not presented in base. But it's there look:
sudo ~/git/rtems/rtems-tools/tester/rtems-tftp-server -v -b
~/sfw/rtems/5.1-smp2-vga80x50-key-to-reset/i386-rtems5/pc686/tests/
RTEMS Tools - TFTP Server, undefined (b1c6a98da4a2)
 Command Line:
/export/home/karel/git/rtems/rtems-tools/tester/rtems-tftp-server -v -b
/export/home/karel/sfw/rtems/5.1-smp2-vga80x50-key-to-reset/i386-rtems5/pc686/tests/
 Host: Linux silence 5.4.0-42-generic #46~18.04.1-Ubuntu SMP Fri Jul 10
07:21:24 UTC 2020 x86_64
 Python: 2.7.17 (default, Jul 20 2020, 15:37:01) [GCC 7.5.0]
] tftp: server: all:69
] tftp: 1: start: 10.0.30.128:2057
] tftp: 1: error: <type 'exceptions.NameError'>: global name
'FileNotFoundError' is not defined
] tftp: 1: end: 10.0.30.128:2057
] tftp: 2: start: 10.0.30.128:2057
] tftp: 2: error: <type 'exceptions.NameError'>: global name
] tftp: 2: end: 10.0.30.128:2057
] tftp: 3: start: 10.0.30.128:2057
] tftp: 3: error: <type 'exceptions.NameError'>: global name
] tftp: 3: end: 10.0.30.128:2057
] tftp: 4: start: 10.0.30.128:2057
] tftp: 4: error: <type 'exceptions.NameError'>: global name
] tftp: 4: end: 10.0.30.128:2057
] tftp: 5: start: 10.0.30.128:2057
] tftp: 5: error: <type 'exceptions.NameError'>: global name
] tftp: 5: end: 10.0.30.128:2057
] tftp: 6: start: 10.0.30.128:2057
] tftp: 6: error: <type 'exceptions.NameError'>: global name
] tftp: 6: end: 10.0.30.128:2057
^Cabort: user terminated
$ ls -la
/export/home/karel/sfw/rtems/5.1-smp2-vga80x50-key-to-reset/i386-rtems5/pc686/tests/smp01.exe
-rwxr-xr-x 1 karel karel 4797752 Sep  7 00:02
so it looks like there is some issue with file handling on tftp server
or have I done anything wrong?
Thanks,
Karel
