RTEMS 4.10 i386 undefined reference to `rtems_bdbuf_configuration'
Heinz Junkes
junkes at fhi-berlin.mpg.de
Mon Sep 7 19:40:15 UTC 2020
> On 7. Sep 2020, at 21:18, Joel Sherrill <joel at rtems.org> wrote:
> It needs to be in an object file defined between rtemsTestData.o and -lCom. Otherwise, there are configuration symbols lacking and the dummy configuration will get pulled in.
Unfortunately I do not understand that. These are all object files?
[h1 at earth test (7.0 *)]$ make -C O.RTEMS-pc386-qemu -f ../Makefile TOP=../../../.. T_A=RTEMS-pc386-qemu install
make: Entering directory '/home/h1/GSOC/rtems5_epics7/QtC-epics-base/modules/libcom/test/O.RTEMS-pc386-qemu'
/home/travis/.rtems/bin/i386-rtems4.10-g++ -B/home/travis/.rtems/i386-rtems4.10/pc686/lib/ -specs bsp_specs -qrtems -o libComTestHarness -static -L/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu -L/home/travis/.rtems/i386-rtems4.10/pc686/lib/ -mtune=pentiumpro -u POSIX_Init -Wl,-Ttext,0x100000 epicsTypesTest.o epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o epicsMMIOTest.o epicsEllTest.o epicsEnvTest.o epicsEnvUnsetTest.o epicsErrlogTest.o epicsStdioTest.o epicsStdlibTest.o epicsSockResolveTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epicsThreadClassTest.o epicsThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsThreadHooksTest.o epicsThreadPoolTest.o epicsExitTest.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o epicsMutexTest.o epicsSpinTest.o epicsAtomicTest.o macDefExpandTest.o cvtFastTest.o macLibTest.o aslibtest.o taskwdTest.o blockingSockTest.o epicsMessageQueueTest.o epicsStackTraceTest.o ipAddrToAsciiTest.o osiSockTest.o epicsRunLibComTests.o epicsThreadPerform.o epicsMaxThreads.o buckTest.o epicsAtomicPerform.o cvtFastPerform.o epicsTimeZoneTest.o rtemsTestHarness.o rtemsTestData.o -lCom -Wl,--gc-sections -lm -lrtemsCom -lc -lrtemscpu -lrtemsCom -lCom -lnfs -lm -lgcc
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu/librtemsCom.a(rtems_config.o):(.data+0x0): multiple definition of `rtems_libio_init_helper'
/home/travis/.rtems/i386-rtems4.10/pc686/lib//librtemscpu.a(dummy.o):(.data+0x0): first defined here
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu/librtemsCom.a(rtems_config.o):(.data+0x4): multiple definition of `rtems_libio_supp_helper'
/home/travis/.rtems/i386-rtems4.10/pc686/lib//librtemscpu.a(dummy.o):(.data+0x4): first defined here
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu/librtemsCom.a(rtems_config.o):(.data+0x8): multiple definition of `rtems_fs_init_helper'
/home/travis/.rtems/i386-rtems4.10/pc686/lib//librtemscpu.a(dummy.o):(.data+0x8): first defined here
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu/librtemsCom.a(rtems_config.o):(.data+0xc): multiple definition of `rtems_libio_number_iops'
/home/travis/.rtems/i386-rtems4.10/pc686/lib//librtemscpu.a(dummy.o):(.data+0xc): first defined here
/home/h1/GSOC/rtems5_epics7/QtC-epics-base/lib/RTEMS-pc386-qemu/librtemsCom.a(rtems_config.o):(.bss+0x0): multiple definition of `rtems_telnetd_maximum_ptys'
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20200907/87ec5349/attachment-0001.bin>
